Battery Suggestions
Battery Suggestions
It's battery replacement time in my '08 Alpha. Can I get some recommendations that people have had luck with other than going with a high end Optima? Thanks
Might I suggest going with an AGM battery. We went with a larger size than stock with a lot more CCAs and reserve. Slight modifications to the bottom of the battery box are required (cutting) and a slightly longer bolt for the strap.
I will have to look at the group # after work.
Thanks Mark, but since I don't do any off roading, have a winch, or an aftermarket high power sound system, I am just looking for a reliable 'drop in' replacement. I know Sam's, Costco, Autozone, etc. all have their own brands, so other than another Delco I was wondering if there might be something as good.
higher power is not needed for regular running. i ran mine on a lawn tractor small batt just to prove it.
i look at warr and buy the biggest that will fit from a z or wally.
actually i have 2 batts and glad i do when main goes dead i can jump from backup. great security.
Used to use those in my boat. Good batteries! Any brand suggestion?
Do you folks in Michigan have farm and fleet stores?
I purchased both gfs and mine for both h3s there and they were the best ones they sold at the time. Platinum series. 3 years no hassle replacement. 7 years pro rated.
As batteries go they're pretty good. Exchange two or three times with no problems.
Under $99 for each one.
