Anti Theft system issues??
Old 05-19-2013, 02:46 PM
Hills's Avatar
Default Anti Theft system issues??
For the third time I have come out to start my truck it clicks once, and goes dead. My key gets locked in the ignition, and the truck won't start. No lights, nothing. I then have to jiggle (not remove) the battery cable. The terminals are all clean. I am thinking I have an electrical issue. I was going to get a new key cut at the dealership. But not sure?
I am concerned because I don't have to completely disconnect the battery cable, just jiggling it makes it unlock the key.
My buddy suggested it might be the anti-theft system kicking in because of a dirty key, or the battery, but it is from 2/11. I have not had the alternator checked either. Could it be the relays? I have had this less than 30 days..
Old 05-19-2013, 03:16 PM
Hills's Avatar
Just went and checked the terminals.. It looks as if someone has repeatedly taken the cables on/off (more wear and tear than a 2007 should have in my opinion.) The plastic cover that goes over the battery looks as if someone has attempted to cut out space so that a better connection can be made.
Old 05-19-2013, 03:37 PM
1 word:
http://stingerelectronics.com/
You can get a pair of stinger terminals cheap on ebay...
Old 05-20-2013, 02:12 AM
Aussie H3's Avatar
Just sounds like dodgy battery terminals, take the terminals off, check them and clean them making sure all connections are clean and tight, make sure body earth connection is clean and tight.
If required replace battery terminals and all should be fine.
Bimmer9938
05-09-2011 02:15 PM
jge82
10-28-2008 07:15 PM
Outlaw Diesel Miami
11-08-2007 07:11 AM
JDEORTA
11-05-2006 11:16 AM
Quick Reply: Anti Theft system issues??
