07 H2 SUT air filter cover
Old 04-01-2015, 07:14 PM
RebelBAC's Avatar
Default 07 H2 SUT air filter cover
Hi everyone,
New h2 owner here and new to the forum. Looking to learn some good stuff from you guys and was hoping to start with a question. I went to look at what kind of air filter is in my rig and noticed that the cover on the air filter is loose and not on properly. I tried and tried to line it up but it looks like the window washing fluid reservoir is pushed up against the air filter box on the backside and I can get the cover over the lip. Am I doing something wrong? It just doesn't seem possible to line it up unless I unbolt the whole box from the truck. I've been looking into installing a cold air intake so maybe I should just do that. What do you guys recommend? K&N or Airaid?
Thanks and I'm looking forward to being part of the forum.
Old 04-01-2015, 07:17 PM
LoJac963's Avatar
It is a royal PITA to get that lid on and off. When I first bought mine I did the same as you, ended up removing that upper support bracket to get the dang lid back on. That was the point I installed my Volant intake and never looked back.
Old 04-01-2015, 07:43 PM
RebelBAC's Avatar
Yeah seems like a terrible design. Have you seen a noticeable difference with your Volant installed?
Old 04-02-2015, 11:36 AM
LoJac963's Avatar
Nothing worth noting. Eventually I also added an AirDoc tube to the Volant for a complete intake system. Looks awesome in there.
The main goal of the Volant for me was to have a easily accessible filter that I can clean, oil, and replace for a fraction of the cost of the stock air filters.
I also run a Volant pre-filter which prevents the actual filter from getting caked with leaves and other junk.
Old 05-02-2015, 05:38 PM
johnygoat's Avatar
Did you notice a difference in fuel economy with the volant?
Old 05-26-2015, 02:33 PM
Baldfox's Avatar
I had same problem with the lid of the airbox. I basically undid just the bolts holding the base of the Airbox to the fender/body and gave it a little tug and managed to get the lid back on. I swapped my standard filter for an aFE Power one
(Afe Pro Dry S Performance Air Filter 11 10088 Air Filters - robbiegibson.com)
I too am rocking an airdoc, which I am very pleased with (airdoc into standard box). Sounds nice and picks up better. Mine is an 09, but imagine yours has a silly seagull for an intake too ! Re the MPG too early too tell from the filter, (did it a week or so ago) but it seems to have smoothed the response out. I originally did the airdoc on its own with standard filter and that made a difference. See my other threads under H2.
Old 05-28-2015, 09:17 AM
LoJac963's Avatar
Not that I noticed. I only check my mpg once in a great while. These things get horrible gas mileage no matter what lol.
PewterTank
12-09-2019 01:41 PM
mastercraft88
01-23-2010 09:37 PM
jstdoitt21
12-18-2007 04:46 PM
Brandon07
40
07-27-2007 08:29 AM
Quick Reply: 07 H2 SUT air filter cover
