07 H2 SUT air filter cover
Hi everyone,
New h2 owner here and new to the forum. Looking to learn some good stuff from you guys and was hoping to start with a question. I went to look at what kind of air filter is in my rig and noticed that the cover on the air filter is loose and not on properly. I tried and tried to line it up but it looks like the window washing fluid reservoir is pushed up against the air filter box on the backside and I can get the cover over the lip. Am I doing something wrong? It just doesn't seem possible to line it up unless I unbolt the whole box from the truck. I've been looking into installing a cold air intake so maybe I should just do that. What do you guys recommend? K&N or Airaid?
Thanks and I'm looking forward to being part of the forum.
It is a royal PITA to get that lid on and off. When I first bought mine I did the same as you, ended up removing that upper support bracket to get the dang lid back on. That was the point I installed my Volant intake and never looked back.
Nothing worth noting. Eventually I also added an AirDoc tube to the Volant for a complete intake system. Looks awesome in there.
The main goal of the Volant for me was to have a easily accessible filter that I can clean, oil, and replace for a fraction of the cost of the stock air filters.
I also run a Volant pre-filter which prevents the actual filter from getting caked with leaves and other junk.
I had same problem with the lid of the airbox. I basically undid just the bolts holding the base of the Airbox to the fender/body and gave it a little tug and managed to get the lid back on. I swapped my standard filter for an aFE Power one
(Afe Pro Dry S Performance Air Filter 11 10088 Air Filters - robbiegibson.com)
I too am rocking an airdoc, which I am very pleased with (airdoc into standard box). Sounds nice and picks up better. Mine is an 09, but imagine yours has a silly seagull for an intake too ! Re the MPG too early too tell from the filter, (did it a week or so ago) but it seems to have smoothed the response out. I originally did the airdoc on its own with standard filter and that made a difference. See my other threads under H2.
Not that I noticed. I only check my mpg once in a great while. These things get horrible gas mileage no matter what lol.
mastercraft88
01-23-2010 09:37 PM
jstdoitt21
12-18-2007 04:46 PM
Brandon07
40
07-27-2007 08:29 AM
