Suggested Maintenance
I own an 05 H2 which I bought new. Other than the water pump going out, I've never had a problem. I change the oil religiously. But now I'm at 84,000 miles and don't want it to break down on me. So to you Hummer experts, what should I have my local mechanic replace? Plugs, wires, radiator flush, change trans fluid, etc.? Thanks
You are really way overdue for fluid changes....trans, cooling system, transfer case, both differentials and brake fluid. Alot of owners change fluids at around 35,000. I had my 2004 H2 done at 50,000 and I do notice an improvement in performance... especially trans shifting.
________
Justin bieber fans
________
Justin bieber fans
I had 04H2 changed every 40,000 miles, all fluids were repleced and the surpintine (Drive belt,a/c) belts replaced......air filter i did.......
Replace the Syn. oil Mobil 1 every 7,000 miles more or less
My water pump also went out at 60,000 miles, had the Coral Hummer dealer ship do the work........
Thats all ive done to it, except tires........Great Truck..........
My wife has the 2006H3
just replaced the Battery yesterday.........No other workdone except Syn. Mobil 1 oil changes
Have a Great day.....................Rick
I've never heard of changing the brake fluid though.
But I've not heard of changing the brake fluid. Is this really needed? If so why? Thanks.
Because of moisture buildup in the fluid. Have a look here
http://www.aa1car.com/library/bfluid.htm
There is a test that the shop can run to check the amount of moisture in the fluid.
________
Big **** Natural
________
Big **** Natural
Got it. I'll get it done.
Another respondant said to change the transmission fluid but don't flush it because it will get metal filings into the gears. Do I need to tell them to NOT flush it, just change it like I do the oil?
