Rims and Tires
Rims and Tires
Hi guys I'am a new member with a 06 Hummer H2 SUV, I have a question about rims and tires, my truck is stock with air ride suspension and I would like to buy 24x12 rims and Toyo open country M/T 37x13.5x24 will they fit without rubbing,and if they do rub would it be alot or a little.thanks
I had a set of 26" wheels with 36"s on mine and it cleared, I think you will probably be fine. The stock tire height is 35", so if you take a ruler and turn the wheels in to where you think it may rub or hit and add an in or so to the tire it will give you an idea of where those tires will be. DO keep in mind that that will be when the vehicle is at rest though and that you will need some space for jouncing of the suspension when you are driving so it doesn't hit.. Hope this helps..
Caraddict
57
03-28-2018 12:42 PM
bighead
08-02-2009 08:54 PM
