Rattling hummer no more
Old 09-12-2016, 10:50 PM
mcioci's Avatar
Default Rattling hummer no more
If anyone has a 2003-2007 hummer H2 and your doors rattle beyond I have the fix for you. Has anyone heard of Dynamat? I bought a box of Dynamat on Amazon, it came with 9 pieces. I put these in each door and the covers that are on both sides of the dash which contains the fuses because they were rattling as bad as the doors. My truck now drives like a new truck. No more noise from doors. It rides like a brand new truck now. The Dynamat costed me $144 but it's well worth it trust me.
Old 09-13-2016, 05:33 AM
atari800's Avatar
Can you explain a bit more?
You took off the interior door panels and the fuse box cover?
I seemed to identify my squeaks coming from where plastic pieces over lap on the doors. Like where power window buttons are. My passenger power window button area was actually broke and quite loose but I hot glued it and it reduced interior noise significantly. I do hear a few squeaks when I hit bumps but I am sure it is interior pieces rubbing against each other.
I am not going to hot glue everything that squeaks.
Since I am the prime driver and love the truck, I hear and feel little things. I'll ask passenger "do you hear that?" and get "hear what? you're nuts"
Old 09-13-2016, 08:41 AM
mcioci's Avatar
I am just like you and I found where all my rattling was coming from. The 2 fuse side covers are a little loose after al these years. If you push in slightly I can hear the plastic make noise. The doors, very simple, the plastic below the door handle and above the area where you can store stuff is very thin and if you press against it you will see the plastic is very thin and hollow on other side. I thought about putting silicone on the inside to make it heavier. My thinking was if its heavier you won't hear as much rattle when going over small or large bumps. My interior guy said just install Dynamat. He showed me what it was and said he uses it under the carpeting and inside doors for better insulation, noise reduction. Now when I close my doors you hear a swish and not a hollow loud sound. I bought it and I have to say my 2005 H2 now drives like a brand new truck. I can't believe it. Trust me guys, it's worth every penny.
Old 09-13-2016, 01:18 PM
atari800's Avatar
How hard/easy was it to remove panels?
I wouldnt want to snap off a clip and really have a rattle to deal with
Old 09-13-2016, 01:33 PM
mcioci's Avatar
you def have to be gentle and I am not so I got my interior guy to remove the panels and put them back on for me.
Old 09-13-2016, 04:25 PM
atari800's Avatar
I read (somewhere) that the glue (or gloop) that holds credit cards on paper in the mail, can be pulled off and pushed into squeaky areas. If you need to remove the panel, the gloop just comes off.
This is a good article - thanks
Old 09-14-2016, 12:50 AM
Baldfox's Avatar
Just to add to this, i had my whole H2 stripped and covered in a similar material to dynamat. This was done more for an audio install, but the doors received the heaviest treatment. The difference is quite staggering. On the freeway you still hear the buffeting from the wind given it's as aerodynamic as a hippo, but in traffic or low speeds, you can listen to the radio at half the volume it was. No squeaks or rattles, it just feels solid. First time i ever used sound deadening. Will be doing it for all my vehicles going forward.
Old 10-20-2016, 01:47 PM
RoH2's Avatar
Good to know it worked! I have some similar material to dynamat and this mod/improvement is on the to-do list.
Old 10-21-2016, 06:20 AM
Baldfox's Avatar
For any of you wanting to see what the doors look like underneath the panel (at least on my '09) there are some pics on my install thread. My doors were covered on the inside and outside of the door shell and on the inside skin with comfortmat (similar product to dynamat) and also on the back of the panels in places. We also used a fabric layer (for isolation i think) in between the panel and the door card. I also thought about putting it on the underside of the hood too, to keep it quiet but am not so sure re temperatures etc...
BabyTank
10-12-2011 06:07 AM
OnAll4s
05-06-2008 08:26 AM
HummerGuy
02-14-2008 12:57 PM
hudson4269
04-09-2007 12:25 AM
LawWyfe
02-18-2007 02:34 PM
Quick Reply: Rattling hummer no more
