Power to R rear tail light
Old 08-17-2010, 04:16 AM
flrtrader's Avatar
Default Power to R rear tail light
I have no power going to the bulb base on my h2... Have blinker, stop, and brakes but no tail light. Also side marker same side does not work... I thought it was just a buld but no dice! I was told the square bulb base has a breaker type set up anyone heard of this? Checked power on prongs in base, guess this weekend I need to test the power on wirers coming into base... I hat electrical BS....
Old 03-05-2011, 06:14 PM
h2_32137's Avatar
Default same problem
Keith.. I have the same problem but on my left side. How did you resolve it? Thanks in advance
Charles
Old 03-07-2011, 03:21 PM
luda81's Avatar
What did you guys try so far? If it had a breaker setup wouldn't it work after an hour after it cooled down? Wouldn't you think?
Old 03-08-2011, 11:07 AM
h2_32137's Avatar
Default tried so far:
So far I have replaced the bulb twice, checked the wires to make sure they aren't loose and I checked the fuses. By the way if anyone needs to purchase a marker light for cheap go to www.gmparts4u.com as they have the best deal so far from my research. I am open to other ideas to try as well. Keep getting pulled over at night!
Charles
Old 03-08-2011, 12:43 PM
colbymh's Avatar
Just out of curiosity, have you checked the contacts for corrosion? You might clean them up with some sandpaper or a file and then make sure the contacts haven't been pushed in to much so there is good contact..
Just a thought
Old 03-08-2011, 02:27 PM
luda81's Avatar
Charles
Did you check the wires to see if you were getting voltage?
Old 04-22-2011, 09:38 PM
h2_32137's Avatar
I am going to mess with it again in the morning. Still out... I rePlaced the left rear marker light too... Nothing. Help
Charles
Old 04-25-2011, 06:05 AM
imhsar's Avatar
but replacing is not the solution.. You should know how to repair it properly.....
Old 05-02-2011, 10:32 PM
h2_32137's Avatar
Still haven't figured it out. Lol
Old 05-11-2011, 05:51 AM
colbymh's Avatar
Did you replace the socket yet?
beachman
Private 'Wanted' Classifieds
05-21-2023 05:50 PM
flrtrader
11-29-2017 01:19 PM
mrmseto
03-20-2010 10:02 AM
BMJM100
01-06-2009 08:47 AM
geeggee
11-20-2008 09:24 AM
Quick Reply: Power to R rear tail light
