No Power and "traction active" message
Old 02-23-2010, 03:30 AM
abdoush's Avatar
Default No Power and "traction active" message
I have two problems and believe they may be connected but not sure how. From a standing stop my 2003 Hummer H2 will lose all power even with the gas pedal to the floor, and some times i see a display message "traction active" and I will hear some noise.
sometimes the ABS light and traction off light come on.
how serious this issue and how can i fix it.
i wanna know before i take it to the dealer not to be over charged.
Old 02-23-2010, 09:43 AM
HumminNBoatin's Avatar
Thats normal if you are on a slippery surface. If this in happening on dry pavement you got problems.
If your on a slippery surface like gravel, mud, snow, wet conditions etc... and you stomp the gass the tires are going to slip. Traction controll is going to kick in to keep the tires from spinning and cut down the throttle at the same time.
bsg424
01-17-2020 10:51 AM
tjwhee
03-06-2014 03:09 PM
carolympus
09-13-2012 07:56 AM
fhydro
12-06-2010 01:12 PM
T REX
09-06-2008 02:14 PM
Quick Reply: No Power and "traction active" message
