Flash to Pass...
Flash to Pass...
When I pull the stalk to activate the flash-to-pass lighting, I don't get anything. The low beams continue to stay on. For what it's worth, the low beams are a bluish color. When I push the stalk forward to activate high beams, the typical yellow/white beam come on and stays on until I pull the stalk back to the neutral position. Any ideas what may be causing the flash-to-pass to not work??
OK. I noticed the headlights are actually 2 bulbs. Looks like an HID and a regular bulb. The regular bulb must be the Hugh beam. That said, would this issue be corrected if I opt for a Bi-Xenon bulb kit? It would be a single bulb (HID) doing the Low and High beam duties...
Doc Olds
12-23-2007 07:34 PM
