Flash to Pass...
Old Nov 15, 2014 | 05:47 AM
MH3's Avatar
MH3
Unhappy Flash to Pass...
When I pull the stalk to activate the flash-to-pass lighting, I don't get anything. The low beams continue to stay on. For what it's worth, the low beams are a bluish color. When I push the stalk forward to activate high beams, the typical yellow/white beam come on and stays on until I pull the stalk back to the neutral position. Any ideas what may be causing the flash-to-pass to not work??
Old Nov 15, 2014 | 11:05 AM
H2Miami's Avatar
Check If you had HID most possible the bulbs are Low beam only ... You need to replace the bulbs for the LO/HI beam or go back to factory lights .
Old Nov 15, 2014 | 06:50 PM
MH3's Avatar
MH3
OK. I noticed the headlights are actually 2 bulbs. Looks like an HID and a regular bulb. The regular bulb must be the Hugh beam. That said, would this issue be corrected if I opt for a Bi-Xenon bulb kit? It would be a single bulb (HID) doing the Low and High beam duties...
Old Nov 15, 2014 | 11:01 PM
H2Miami's Avatar
Mine is a single bulb LO/HI .. works perfect . I had it for 3 years already and still strong
sfgiantsfan9
Sep 1, 2009 09:51 PM
mwalker141
Jun 3, 2009 06:01 AM
Doc Olds
Dec 23, 2007 07:34 PM
TigerLily
Jan 17, 2007 01:34 PM
HummerGuy123
Jul 28, 2006 02:27 PM
