Go Back   Hummer Forums - Enthusiast Forum for Hummer Owners > Hummer Lineup > Hummer H3 > H3 Frequently Asked Questions
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Hummer Forums - Enthusiast Forum for Hummer Owners.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Reply
LinkBack Thread Tools Search this Thread
Old 06-17-2007, 12:49 PM
Default replace bulbs 4 fog lights and side marker lamps
Hey anyone out there know how i can replace my bulbs for foig lights and side marker lamps? without going to dealer that is...
This ad is not displayed to registered members.
Register your free account today and become a member on Hummerforums!
Old 06-17-2007, 08:56 PM
Default RE: replace bulbs 4 fog lights and side marker lamps
Hey Ray..
I think you can get to the fog lamps by reaching into the bumber area from underneath...But the side markers, I believe you have to remove the wheelwell liner to get at them..still no biggy, just a PITA,cuz you should take your wheel off to do it...
Old 06-22-2007, 07:59 AM
D VADER's Avatar
Quote:
ORIGINAL: Dennis
Hey Ray..
Dennis,
I noticed the wheel well liners are also secured with large staples. Can those be removed and re-applied?
__________________
[b]2007 H3X w/lux pkg, black on black, Starship from the "Dark Side"
Central Ohio[b]
Old 06-22-2007, 08:00 PM
NO! leave those alone..those are the high dollar, special stainless staples..they hold the rubber skirting to the wheel liner..you have to pop loose and remove all of these button rivets...
Click the image to open in full size.
Old 06-29-2007, 02:50 PM
Dennis, before I destroy these plastic fasteners do I need a special tool or will gentle prying pull them out?
Old 06-29-2007, 10:16 PM
See that notch in it?...Take a small screwdriver and pop that center plug out and then the rest of the fastener will come out.
Old 07-01-2007, 03:28 PM
Figured it out. I replaced the turn signal indicators with the European clear lenses from ebay and used the Sylvania Silver Star chromed turn signal bulbs. I had to remove the wheel well liner by removing all of the plastic fasteners (about a dozen) as well as the mud flaps. Left the wheels on, had enough clearance.The bulb is easy to get to but to remove the whole unit you have to take off the front grill (6-10mm bolts/nuts). Not a bad job at all, took about 45 minutes on the first side, 25 minutes on the second side once I had it figured out.
And it was 105 degrees out, maybe 104 in the shade.
Old 09-28-2007, 12:44 PM
hilljob26's Avatar
now see,w/out you guys doing this,i never would have known
__________________
dont sweat the petty stuff,pet the sweaty stuff
Old 04-14-2009, 01:57 PM
[QUOTE=Take a small screwdriver and pop that center plug out and then the rest of the fastener will come out.[/QUOTE]
Dennis / alrock-
My center plug has two notches (one on each side of the fastener). Did you use a small screwdriver on each side or was one side sufficient? Do you recall how much force you had to use? I hate when I break fasteners
-mountainbiker
__________________
Hybrid Emblem ~ GM Grille Lights ~ GM Hood Insulation ~ PCM ~ SMA Light Bar ~ HitchCAM ~ Cepek Wheels ~ Dueler A/T Rubber ~ 20% tint ~ DICE iPod Adapter ~ Optima ~ "European Lights"
Reply
Tags
2007, bulb, bulbd, bulbs, fog, front, h2, h3, hummer, lights, marker, markers, remove, replace, side, sidemarkers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
