replace bulbs 4 fog lights and side marker lamps
Old Jun 17, 2007 | 12:49 PM
raygonz's Avatar
Default replace bulbs 4 fog lights and side marker lamps
Hey anyone out there know how i can replace my bulbs for foig lights and side marker lamps? without going to dealer that is...
Old Jun 17, 2007 | 08:56 PM
Dennis's Avatar
Default RE: replace bulbs 4 fog lights and side marker lamps
Hey Ray..
I think you can get to the fog lamps by reaching into the bumber area from underneath...But the side markers, I believe you have to remove the wheelwell liner to get at them..still no biggy, just a PITA,cuz you should take your wheel off to do it...
Old Jun 22, 2007 | 07:59 AM
D VADER's Avatar
ORIGINAL: Dennis
Hey Ray..
Dennis,
I noticed the wheel well liners are also secured with large staples. Can those be removed and re-applied?
Old Jun 22, 2007 | 08:00 PM
Dennis's Avatar
NO! leave those alone..those are the high dollar, special stainless staples..they hold the rubber skirting to the wheel liner..you have to pop loose and remove all of these button rivets...
Old Jun 29, 2007 | 02:50 PM
alrock's Avatar
Dennis, before I destroy these plastic fasteners do I need a special tool or will gentle prying pull them out?
Old Jun 29, 2007 | 10:16 PM
Dennis's Avatar
See that notch in it?...Take a small screwdriver and pop that center plug out and then the rest of the fastener will come out.
Old Jul 1, 2007 | 03:28 PM
alrock's Avatar
Figured it out. I replaced the turn signal indicators with the European clear lenses from ebay and used the Sylvania Silver Star chromed turn signal bulbs. I had to remove the wheel well liner by removing all of the plastic fasteners (about a dozen) as well as the mud flaps. Left the wheels on, had enough clearance.The bulb is easy to get to but to remove the whole unit you have to take off the front grill (6-10mm bolts/nuts). Not a bad job at all, took about 45 minutes on the first side, 25 minutes on the second side once I had it figured out.
And it was 105 degrees out, maybe 104 in the shade.
Old Sep 28, 2007 | 12:44 PM
hilljob26's Avatar
now see,w/out you guys doing this,i never would have known
Old Apr 14, 2009 | 01:57 PM
mountainbiker's Avatar
[QUOTE=Take a small screwdriver and pop that center plug out and then the rest of the fastener will come out.[/QUOTE]
Dennis / alrock-
My center plug has two notches (one on each side of the fastener). Did you use a small screwdriver on each side or was one side sufficient? Do you recall how much force you had to use? I hate when I break fasteners
-mountainbiker
dilo2001gt
17
Feb 15, 2016 12:40 PM
lvu
Nov 8, 2013 08:42 AM
R1guy777
Nov 10, 2010 07:48 PM
pmalla5
Jul 20, 2007 10:08 PM
melvynray
Dec 8, 2006 01:08 AM
