H2 solid axle conversion
Old 10-29-2014, 04:04 PM
h2offroad's Avatar
Default H2 solid axle conversion
I've been kind of obsessed with the thought of having a straight axle on the front of the hummer h2. It would be a beast.
As far as I know, the front of the H2 frame is the same as the 2500 frame.
My question is, would I be incorrect in thinking I could use a solid axle conversion kit made for the 2500?
thanks!
Old 02-02-2015, 08:51 PM
h2offroad's Avatar
Gonna go ahead and bump this old guy.
Old 02-03-2015, 09:06 AM
citiboy's Avatar
It's been done before.
H2 Hummer SAS Solid Axle Swap
Old 02-03-2015, 09:24 AM
h2offroad's Avatar
Been to that link many times before.
that's a totally custom setup and atleast 12-15 inches of lift.
My question is about the front of the H2 frame vs the the 2500hd frame.
Old 02-03-2015, 10:51 AM
citiboy's Avatar
Just to give you an idea, as you know the H2 shares the same front frame with 2500HD.
Off Road Unlimited Solid Axle Conversion, Convert your IFS to a Solid Axle
Signal25's Avatar
All the 2500's Ive looked under look the exact same as the H2, to me. But Im not comparing every hole, and nook and granny. Ill start paying better attention.
I think it would be an awesome project. The kits are around $1500 an then just finding and axle and any mods you want to do to it.
Old 02-03-2015, 11:17 AM
h2offroad's Avatar
Exactly. I really think it can be done way cheaper than most believe.
I saw a thread somewhere that said 03+ dodge front axle work with the electronics. Any insight on this?
http://www.hummer4x4offroad.com/foru...-solid-axle-H2
Old 02-03-2015, 12:14 PM
Signal25's Avatar
Low budget solid axle H2...
I dont have any insight. Most of my 4WD experience is with late 80's Fords when things were simple. No computers involved. A swap meant adding another lever to your floor board. And you had to get out of the truck to actually put it in 4WD. Bet very few here remember them days.
So far I haven't found anything really documenting a SAS on a H2.
Maybe you need to be the 1st....................
Old 02-07-2015, 07:08 PM
Signal25's Avatar
Theres a 10.5 14 bolt, and Dana 60 for sale local to me...........
Had a funny hair to try this swap, but all the reading I've done its not worth it.
Id like to get the 10.5 14 bolt, but the guy wont separate.
motley1987
01-10-2022 01:08 AM
Greenblade
03-03-2018 03:33 AM
Demlockian
11-26-2013 07:25 AM
ShopSAR
04-11-2008 08:06 AM
ShopSAR
12-05-2006 06:05 PM
Quick Reply: H2 solid axle conversion
