Looking for parts
I’m looking for a good h3 l5 crank. Anyone know where I might be able to get one. It’s my daughters car and I apparently failed at teaching her maintenance, she ran the thing out of oil.
Many help would be appreciated
jack
jack
What year I5?
Not sure what they changed between 2006 (3.5L) and 2007-2010 (3.7L) to gain the added cubic inches.
Bore (cylinder wall size) or Stroke (different crank or shorter piston rod).
This "could" make s huge difference in what you are looking for.
Colorado/Canyons had the same I5 engines. Try on those forums also once you know specifically what you need.
It would be much easier and less $$ to just pull the engine and swap with a used one. As Mark mentioned above, the year H3 makes a big difference. A used engine ranges from $500 to $3,000 depending on year and miles and for reference it takes us a full day (two guys) to swap a engine and completely wrap everything up if we do not run into any major issues with rusted/ broken bolts etc.
