XM/Onstar antenna
Old Sep 20, 2012 | 10:24 AM
PaulB's Avatar
Default XM/Onstar antenna
OK, here's a tough one. The rubber/foam part of my XM/Onstar antenna (shark fin) has broken in half. Went to the dealer to buy a new one. He brings out a replacement that looks similar but it just twists in place. Mine is attached to the base with two small torx screws. He says they must have changed the design mid-year. His book doesn't even show mine. I would have to buy a new base that accepts the new twist-on antenna. And it looks like the base is removed from under the roof, above the head liner. I have an 05 H2. We even checked the 04 model to see if maybe my style was listed but that antenna is totally different. Any suggestions? Thanks.
Old May 21, 2016 | 12:26 AM
Dry Heat's Avatar
Default Anttenaaa P/N 20842596
I know this is a old post, but maybe some will be looking jut as I was for this antenna. P/N 20842596. Check E-Bay priced as low as $18.00 to $40.00. Just unscrew broken antenna and screw in new one. No need to remove the base.
Old May 21, 2016 | 09:10 AM
PaulB's Avatar
This is the version I mentioned in my original post. This does NOT fit my H2. It is the twist style. These are available everywhere. Amazon, the dealer, ebay, etc.
Old Jul 17, 2019 | 03:55 PM
Thelegend's Avatar
Just bought a 2005 H2 have the same problem with the antenna did you got the right antenna
Old Jul 17, 2019 | 07:36 PM
PaulB's Avatar
No never did. Had to rebuild mine using bonding putty.
Threedog
Jun 29, 2014 05:41 PM
VMAC
Dec 31, 2013 06:47 PM
staggs
Jul 14, 2012 11:27 AM
drtom
Apr 20, 2012 10:50 PM
crank
Jun 17, 2007 08:51 AM
