Xbrite led halo headlights
Old Jan 23, 2018 | 03:07 PM
Hiro's Avatar
Default Xbrite led halo headlights
Electrical help.
i recently purchased some headlights off of Amazon
full kit kit for fog lights as well
have everything fit into place. The converter cable that came with it was not to a 9007 so I had to splice the wires to match up.
right now only the DRL are turning on
when I turn the high beams on, the left side goes out. And the right side gets dimmer.
any suggestions?
Old Jan 23, 2018 | 07:05 PM
LoJac963's Avatar
I would double check all of your splicing and wiring. Make sure everything is soldered and heat shrunk for good connections. Take a test light and make sure you are getting 12V at each connector when functioning through the various light settings.
You would have been better buying converters instead of cutting up the stock harness FYI.
H2 Chief
May 15, 2020 11:01 PM
worknit
18
Mar 29, 2017 10:23 PM
Man1nboat
Nov 5, 2013 09:48 PM
kakash
Mar 15, 2012 04:24 PM
HummersRTS26
Feb 26, 2011 06:22 PM
