wrong housing thermostat problems
Old Oct 15, 2013 | 11:20 PM
Philip Larocca's Avatar
Default wrong housing thermostat problems
have a 2007 h3 with the inline 5 cylinder 3.7 and the thermostat housing has a 90 on it pointing towards the front of motor the replacement at auto zone and o rileys has a inlet with it coming strait out of the motor going towards the passenger side of the h3 went though every motor hummers came out with but none match the one on it the strait one would be coming though the power steering pump any one come across this problem
Old Oct 16, 2013 | 12:06 PM
MOVED for you to the correct section. If you have a question regarding a H3, .............. ask it in the H3 section.
Order the correct GM T Stat parts from a GM supplier, like GMpartshouse.com or others. #305
Welcome to the forums.
Old Oct 16, 2013 | 02:43 PM
happythree's Avatar
hey,i just remembered, I checked my ps fluid sat and the pump is up on the right side where that rightangle thing is. it looks like a water hose fitting number 308. the STRAIGHT thing number 305 appears to be a housing for the thermostat.
so it depends on what you really need.!! I bet you did not find your t stat in the 308 thing!
Old Oct 16, 2013 | 02:55 PM
#308 if the engine coolant outlet, ain't no T Stat in that.
So yep, you be looking at the wrong thing.
Old Oct 16, 2013 | 08:43 PM
egroegart's Avatar
Yep, he's looking at the wrong thing. I made that mistake too when I changed it a couple years ago.
bheff
Jul 11, 2011 03:06 PM
jandmtv
Jun 2, 2011 06:17 PM
raveniskcrow
Jan 30, 2010 07:22 PM
c3 rolling
Jan 23, 2009 06:30 PM
veves
May 31, 2008 09:34 PM
