Wire Colors for Subwoofer
Old Nov 23, 2011 | 09:59 PM
austinoliveira's Avatar
Default Wire Colors for Subwoofer
I'm installing a subwoofer in my '08 H3 Alpha, and I need to get the wire colors for the subwoofer audio signal that run through the left side panels that run under the door. I have the power wire, ground, amp turn-on wire, and everything working properly, except for the audio signal. I used the left rear door signal, but that ended up not going anywhere below 40hz. Please help me out.
Old Nov 24, 2011 | 09:03 AM
drtom's Avatar
Banned
IM OUTTA TOWN so i cant look, but u can, just download the entire svc manual in 3 min for 15 bucks!
Old Nov 24, 2011 | 02:42 PM
Thanks, when you get home, could you check, that would be VERY helpful. I don't want to take apart the wheel well to get the signal from the sub itself, because that is too much work and I would probably break all the clips.
Old Nov 25, 2011 | 09:13 AM
drtom's Avatar
Banned
if u have a subwoofer u have a monsoon system right?
the sub is connected direct to the amp in the fender area. if you r replacing a sub you need to...replace the sub!! i dont know what else u can do!
if u dont have a sub, u dont have wires for a sub
Brent Whitfield
Feb 12, 2014 06:40 PM
jasontag
Apr 26, 2010 10:08 AM
mushyizcool
19
Feb 12, 2008 08:26 PM
hummer
Aug 23, 2007 04:49 AM
firefly38305
Mar 9, 2007 01:11 AM
