Windshield Rattles when Driving
6 Attachment(s)
I have owned several H2s and 100% of my 2003's have had this, so I'm thinking the 3M mount tape Hummer used on the Windshield Garnish Reveal Molding (GM Part 20787557 & 20787558) is only lasting 13 years or so.
Therefore, if you own a 2003 or 2004 or you have had your windshield replaced (check if you have a GM windshield for those that bought pre-owned) then there is an extremely high probability you have these rattles and perhaps are so use to it, you don't even know it. An easy test: temporarily take some chewed chewing gum and squeeze under your moldings and drive the truck to see if it doesn't quieten the wind noise. To rectify the issue you will need a philips screw driver, Goof-Off, and 1/2" 3M Scotch Mount Molding Tape, and 1 hr of time: Step 1: Attachment 9982 Start at the top of your Upper Door Weather Strip and pull this away from the body of the truck over the front door area and down the A-pillar and then un-hook it from the bottom of the Molding. Step 2: Attachment 9983 Remove the two philip screws. With both hands take the molding and slide it down slightly to pull the molding away from the top trim, then un-hook the molding from the cowling below. Step 3: Attachment 9984 Here you will see 3M strip that no longer have their adhesion. Remove the old molding tape and complete by removing any tape residue with Goof-Off. Goof-Off is also great as an adhesion promoter for the new tape. Step 4: Attachment 9985 Apply new tape as shown leaving about 1mm from the edge. In fact you will begin to feel a lip as to where the tape should go. Also, remember to replace the small tape piece on the lower part of the molding as well. Step 5: Clean your A-pillar on the body of the truck really well. Don't forget to remove that small piece of tape that will most likely remain on the truck within the door jam. Acetone or Alcohol that area where the tape was along with your windshield to promote good adhesion to your new tape. Step 6: Remove red tape backing and reinstall your molding by hinging in the bottom section into the cowling, and without allowing the tape to touch, lip the top section under the body trim. Once you feel you are centered, then set the tape by pulling the molding in to the truck. Replace the two screws while continuing the pressure on the molding to ensure a good seating of the tape. Also ensure the lower tape piece is nicely seated as well. Step 7: Attachment 9987 Re-hook your Door Weather Strip on the bottom of the molding first. If hooked correctly the Door Weather Strip fits flush along the molding as noted in the picture. Then stretch the Door Weather strip up until the cleat is seated nicely between the molding and upper body trim. Finish seating the rest of the weather strip above the doors. |
Great job on the how to!
Common problem for most H2's. My 06 had the issue on a trip to northern AZ. The rattle was so loud at highway speeds I had to pull over at a gas station. 3M tape and you're good to go! |
I have the same problem. 75 mph and the rattling starts to out play the radio. I'll do the 3m tape today.
Originally Posted by Dry Heat
(Post 343611)
From Phoenix! Glad to have you here! I'm out in the far west valley. |
My sunroof starts rattling at 70mph. any fix for that?
Do you have the front stock wind deflector?
Originally Posted by LoJac963
(Post 343626)
Yes I have the stock wind deflector. I read that it does that. Is it easy to remove?
(Post 343676)
I work on the West side. Out at the Goodyear Airport. I plan on fixing this noise and pulling the "OnStar" unit this week.
Nice, I used to work at West Valley Hospital for 5 years so I know the area! |
Thanks just got an H2 so I had no clue what that rattle was. The dealer just replaced the windshield so it makes sense.
