Will this A/C unit work on my 93?
Old Jun 14, 2008 | 10:59 PM
Todd's Avatar
Default Will this A/C unit work on my 93?
Can I make this work some how on my 93?
http://cgi.ebay.com/ebaymotors/Heate...spagenameZWDVW
Old Jun 15, 2008 | 09:04 PM
phazer42's Avatar
Default RE: Will this A/C unit work on my 93?
will it fit? yes.... will you need to do some mods.... yes.... if you are comfortable with that.... then have at it..... it appears the be the "upgraded" unit.... which would also require you to change your electronics and your control switch for the HVAC as your current style will not operate this one.... I believe you might also have to install a vacuum pump - as the doors are all operated by vacuum on the newer unit.....
take a look here:
http://flashoffroad.com/humdefault.htm
or
http://www.hummerknowledgebase.com/H1.html
Old Jun 16, 2008 | 08:24 AM
Todd's Avatar
Thanks!!
Old Jun 16, 2008 | 09:16 AM
2doorh1's Avatar
the best bet on an H-1 is stayOEM if you can
Old Jun 16, 2008 | 02:57 PM
phazer42's Avatar
ORIGINAL: 2doorh1
Thats not always the case.... folks with a '96 are heavily favoring the 97.5 HVAC upgrade as prior to the upgrade, you would struggle to get your windows defrosted.... and the system is just totally inadequate.... but... granted there are less changes between 96 and 97.5 then there are between 93 and 97.5
Old Jun 16, 2008 | 03:37 PM
Some upgrades/updates ( 97.5 HVAC, butterfly mirrors, Alpha steering wheel, 17" wheels & tires ) just make too much sense not to do. These things not only make the truck more enjoyable but increase value as well.
Old Jun 17, 2008 | 08:07 AM
2doorh1's Avatar
I agree on anything such as you listed 3hummers, but anything mechanical I personally would stay stock. The reason being is you can hardly find anyone to work on an H-1 now, and if it has been modified that just makes it harder to get correct parts etc. That is just my opinion, a lot depends on you local area and service/support available. Now the A/C is a different animal to some degree because I do not even know if they make the original for that year anymore. With many changes come changes to the wiring harnesses, etc. and hacking into those is just not what I would want to do.
Old Jun 17, 2008 | 08:11 AM
There are a lot more spares parts for the later models than the early years. That could force you into an upgrade to later year systems.
Tram
Jul 21, 2011 12:08 PM
JeepeaterH3
Nov 28, 2007 02:14 PM
Trey124
Feb 22, 2007 02:33 AM
CCMDoc
Feb 4, 2007 08:36 PM
whth3
Dec 28, 2006 12:24 AM
