Where is the oil pressure sending unit located?
Old Feb 19, 2015 | 12:37 PM
Wfive's Avatar
Default Where is the oil pressure sending unit located?
My oil pressure gauge on my dash was working on and off. Seemed like a short...but now does not work at all. reads zero... So I replaced the gauge and checked wires and still the same issues.
Where is the oil pressure sending unit threaded into the engine? Is it located on the block where I can get to and check it's harness, or replace easily? I already have a new one.
Thanks!
Old Feb 26, 2015 | 11:01 AM
Wfive's Avatar
Anyone?
Old Mar 1, 2015 | 01:03 PM
wiretap's Avatar
Here's how the gauge should be wired per a post on The Hummer Network:
S - Sender (should be a single Tan wire)
I - Power/ignition (should be gray wire, goes to (or from) the voltmeter)
G - Ground (should be a black wire, goes to (or from) the voltmeter)
There are the light wires as well (black and purple).
Looking at the gauge, going clockwise:
Top (12 o'clock) is tan (sender)
Right (3 o'clock) is gray
Bottom (6 o'clock) is light (violet and black, violet got angry with me for calling her purple above!)
Left (9 o'clock) is black.
Info on the sender unit from The Hummer Network
AM General Parts:
5744455 - NA trucks '96-'98, maybe TD too
5745120 - '99 and later TD except Alpha
AC Delco - GM Part:
19244500 - 3-pin
GM Part:
12558074 - For the single-pin sensor
5744455 is the 3-wire sending unit / pressure switch used in '96 through '98 TD trucks. It is correctly identified in the '96 manual, but is incorrectly listed in the '97 and '98 manuals as the unit for the N/A trucks "ONLY". It was used for both the N/A and TD trucks in '97 and '98.
In '96 and earlier N/A trucks (and the gassers), P/N 6000092 was the oil pressure switch, with a separate oil pressure sending unit (P/N 6001037).
In 1999 AMG changed to the 1-wire sensor P/N 5745120. The change was caused by the PCM's takeover of the lift pump operation (based on engine RPM instead of oil pressure). There was no longer a need for an oil pressure switch -- only a sensor for the gauge.
More confusion is also available: The 1-pin and 3-pin sensors use the same connector, install in the same location, and look almost identical but for the pin population. I am not sure, but I believe that a 3-pin sensor can be used in place of the 1-pin sensor, though not the other way around.
Here's where the sending unit is located. You have to remove the interior dash / doghouse and firewall panel to get to it.
Old Mar 2, 2015 | 12:47 PM
Wfive's Avatar
Very helpful thanks!!! Anyway to get to sending unit with out going through doghouse? Mine has been customized and it would be near impossible to remove without having to rewire things all over again...
Old Mar 2, 2015 | 01:10 PM
wiretap's Avatar
You can attempt to get at it from the front driver side.. the best way is to go look. I really doubt you'll be able to. It is down between the heads and there's a lot of stuff in the way.
SteveSS
Dec 5, 2022 10:55 AM
RAHF
Oct 29, 2014 07:27 AM
wfturner
May 9, 2011 06:00 PM
Kevinhubbard
Dec 18, 2010 10:36 PM
Alfredohartwig
Dec 13, 2010 06:14 AM
