Which wheel will fit my H3?
Old Jul 16, 2007 | 09:52 PM
straycat's Avatar
Default Which wheel will fit my H3?
Hi, I'm trying to get steel wheels for my 07 H3 and Ihave no idea which size I shoud get.
Here's the link...
http://www.4wheelparts.com/PPT3363T100021.aspx
Which one will fit? Could I use my stock tires with them? (265/75R 16)
Or...if you know any black steel wheels that will fit H3...please let me know.
Thanks!
Old Jul 18, 2007 | 01:07 AM
pmalla5's Avatar
Default RE: Which wheel will fit my H3?
if they are the same size rim and same bolt pattern the tires should fit fine from your old rims. unless they are wider?
Old Jul 18, 2007 | 04:33 PM
telcobilly's Avatar
I just went through a wheel disaster today. I too wanted black steel wheels with a simulated beadlock look.. Discount Tires had these rims listed for the H3. http://www.discounttire.com/dtcs/fin...009662&bp= They went on and looked awesome, so I thought I was good to go. Then I backed out and felt a jerking through the wheel. Upon further examination I found out the rims contacted the front brake calipers, uh ohhh. Ended up putting the stock rims on, as Discount wouldn't do spacers (needed about 1/2") They weren't too happy either with the tech dept that said they would fit..... I can't find a comparable replacement that I like...
Old Jul 18, 2007 | 05:20 PM
straycat's Avatar
yeah..I went to local 4x4 shop and they said Pro Comp steel wheels will fit but they'll stick out too much. Instead they recommended me steel wheels from American Racing (16x7)
http://www.americanracing.com/wheels...mp;section=ORT
I don't know if they're gonna have same caliper problems...
Maybe I should go for 17"...
Thanks for the info!
Old Jul 18, 2007 | 08:51 PM
telcobilly's Avatar
No problem! I know if I had used a spacer, it would have worked. Would a relatively thin spacer (1/4") still cause problems on the H3?
jsbihn
Jan 24, 2015 11:13 PM
stinger95
Jun 13, 2011 11:41 AM
CodyB
May 21, 2011 09:11 PM
c3 rolling
Oct 20, 2008 01:14 AM
j e f f x o 6 x
16
Jul 20, 2007 02:29 AM
