Wheel spacer or Level the front end?
Old Nov 13, 2009 | 12:53 AM
2wheelmonster's Avatar
Default Wheel spacer or Level the front end?
I was wondering if anyone bought wheel spacers to accomodate a bigger tire like the 315/75/R16, instead of leveling out the front end with a taller shock and turning up the torcian bars to raise it up? I hope I spelled torcian right!!!
Old Nov 13, 2009 | 06:45 AM
DAGKANA's Avatar
Nope, I leveled the front end, a wheel spacer isn't gonna really do anything for you, other than move the larger tire away from the sway bar, no need. I did the "torsion" bar approach and got the larger shocks, with the extra weight on the nose I was having really bad nose dives when braking, so much better with the other shocks... definitely worth the $200 IMO
Old Nov 13, 2009 | 04:11 PM
oruna1's Avatar
Talking
I personally think that wheel spacers are a bad idea. 315's fit on stock wheels with no problem other than if turning hard against the stops some tires may tickel the sway bar. The best thing to do is always keep the same wheel offset as stock because the unit bearings (wheel bearings) are designed to support the weight properly at the stock wheel offset. Anything other than the stock offset adds an additional stress component on the bearing assy which can cause premature failure of the bearing. My 2 cents!
Old Nov 15, 2009 | 04:32 PM
thanks for the information, I want to level my front end out but don't know how to do the torcian bar method?
Old Nov 15, 2009 | 04:49 PM
oruna1's Avatar
It works perfectly fine. There are a bunch of threads on this. Do a search and you'll find all the info you need.
Old Nov 15, 2009 | 05:44 PM
thank you
Old Nov 15, 2009 | 06:16 PM
slumlord's Avatar
I did the leveling kit and still had to put 1/4 inch spacers on to stop the rubbing. The tires when turned all the way would rub on the 1" str. stab. bars that are in front of the tie rod ends. I can still feel or hear it if I hold real hard to turn tight. Might should have gotten the 3/8 or even 1/2 inch spacers. I put the spacers on all four corners. Even at 1/4 inch I didn't want to be able to tell a difference from front to back.
jsbihn
Jan 6, 2015 10:48 PM
Maxx
May 31, 2014 10:40 PM
Indy
Sep 18, 2013 11:30 AM
Bullwheel
Jun 9, 2011 11:31 PM
Bennersj
Jul 21, 2007 12:09 PM
