Wheel off set
Old Jun 15, 2012 | 12:35 PM
Mr. Orale's Avatar
Originally Posted by H2CANEPADESIGN
The diameter of your stock tire is 34.5". the diameter of the nitto is 35.12"
Your stock wheel is a 17x8.5 with a 22mm positive offset.
The best offset is going to be a slight positive, like what you have. if you have a lower, or more negative offset the wheels will stick out further from your wheel well and may potentially rub. also how wide are the 20s that you are installing?
This is a 6 year old thread. Might want to consider thread title/dates next time man.
Old Jun 15, 2012 | 12:38 PM
H2CANEPADESIGN's Avatar
Originally Posted by importkiller
ok, I called my friend that owns a rim place, he said stock is -18 offset but that most aftermarkets are zero and +10 offset. At least in the 17-18" size, I forgot to ask him about 20's but more positive offset will only make the tires stick out of the wheel wells a little bit and not damage anything. My H3 has -38 stock and I went with +12 rims and they fit fine and look much more aggresive sticking out a little..IMO. heres a pic of how much a change from -38 to +12 looks
Also your stock tires are 315/70/17 I think. They equal 34.4x 12.4
the ones you are interested in are 325/60/20 they equal 35.4x12.8 so you may see a small ride height increase but not much at all.
hope this helps!
Your stock wheels (if they were 16s) were a positive +30 offset, the wheels you bought were actually more negative of an offset (+12)and that is why they stick out. Negative offset means the center of the wheel is pushed more toward the backside of the wheel (hence the wheel has a deep dish and sticks out) positive offset ( like wheels you see on a front wheel drive car_will tuck under the fender..the lugs will be toward the "face" of the wheel so they will not have a deep dish. Most all wheel drive and four wheel drive vehicles have a slight positive offset. front wheel drives have a high positive offset. rear wheel drives have a 0 or lower (negative) offset so you get that deep dish look.
Old Jun 15, 2012 | 12:43 PM
DOH, Came up as an unread thread. Your right, feel like a buffoon.
AvrgJoe
Aug 12, 2012 03:30 PM
hearseman
Aug 5, 2010 09:26 PM
augustin01
Jun 18, 2008 06:07 PM
BrokenAxle
Oct 23, 2007 07:30 AM
Zero
Sep 17, 2006 03:12 PM
