Wheel center cap retention
Old Nov 16, 2012 | 08:54 AM
Navadisha's Avatar
Default Wheel center cap retention
Anyone have tips for more securely (re)installing stock wheel center caps?
Only ever lost one in the past 5 years.
Got home last night after going to a brushless car wash and not one but two were missing.
Went back this morning there they were on opposite sides of the bay.
Not confident on just popping them back on.
early on the dealer suggested dabs of superglue but this forum is a much smarter bunch.
Couldn't find anything about this searching the forum.
Old Nov 16, 2012 | 09:40 AM
You had a tire shop do rotations and put the caps back on? didn't you?
When you off road a 3 with OEM wheels, the first thing dang near everybody does is pull off the C Caps, so they do not get trashed, sucked off in the mud, or lost. So when you go for a rotation, pull the caps off before giving them the key to pull it in the bay. They stay on indefinitely when you, the owner, puts them back on, instead of the hungover tire monkey at the shop.
First inspect the inside of the C Cap. Note the position and presence of all the tabs and the all important spring wire. I noticed a bunch on ebay have missing tabs or missing spring wire, those are not gonna stay put. The spring wire has to be in position to keep pressure on the plastic tabs, and there is a groove in the tabs for the spring wire to keep it in place.
If all the tabs are not straight, you need to line them up against the wire. Most H3 caps have the clock hand "Hummer" thing sticking out to 3 O'Clock, line that up where it goes in the wheel, then push it into position and give it a swift tap to pop it on, without bending under any of the plastic tabs.
You can just ***** nilly pop them on, it will bend under a tab or two, and that is where the trouble starts. If you want it done right, do it yourself.
Old Nov 16, 2012 | 09:53 AM
Navadisha's Avatar
How'd you know??
Awesome, thanks so much. This is very, very helpful!!!
Old Nov 16, 2012 | 12:24 PM
Xlr8n's Avatar
I believe at some point during production, GM quit putting the spring wire in the center caps. Not sure when or why, but most of the newer H3s I've seen don't have springs in place.
My '08 didn't have them when I bought it used. I haven't lost a cap yet, but I'd sure like to find a set of just the spring wires.
Can anybody come up with a part number for just the spring hoops?
Old Nov 16, 2012 | 02:29 PM
I think the Lux pkg wheels may not come with the wires? Not sure.
Old Nov 16, 2012 | 02:33 PM
Broken Halo's Avatar
Just checked my 08' Alpha....they're there
Old Jan 9, 2013 | 01:55 PM
Navadisha's Avatar
Coming back around to this. Mine does not have the spring wire and they are base model wheels, '07.
I've subsequently lost another one in the past month. Starting to wonder if there's a fatigue age with the plastic tabs or something.
Any one have suggestions for a little additional help to keep them on?
Old Jan 9, 2013 | 03:31 PM
Xlr8n's Avatar
The spring hoops mentioned above force the tabs outward and keep pressure on them so the tabs don't lose there shape over time. Your best bet would be to track down or fabricate some wire spring hoops.
Old Jan 10, 2013 | 03:58 AM
06s and 08s have springs so do 09 and 10s. Never owned or worked on an 07 so I can't say for sure.
Sounds like someone replaced some stolen OEM caps with junk ones without the springs.
Old Jan 10, 2013 | 06:14 AM
Bunger's Avatar
My 07 has NO springs.
The pair of rims that I bought for the adventure trailer came off of an 07 and they had no springs.
