What's that noise and that thing?
Old Feb 15, 2014 | 06:26 PM
Justinh's Avatar
Default What's that noise and that thing?
Got a 2-in-1 post...
1) The noise: A reverberating noise (similar to a loose heat shield) has developed. It most often happens just before I come to a stop, and lasts 1-2 seconds. It sounds like it is on the passenger side in the dash area. It can be continuous while stopped in reverse if the engine is cold. It is tinny or plastic-y. Any ideas - common things to look for?
2) The thing: While I was looking for suspects for the noise, I was looking behind the dash in the glove box opening to the right. There is a metallic (?) looking box (maybe 3" sq x 1" thick) snapped into a large plastic bracket just below the (rear-facing) air vent. The bracket covers most of the box from the glove box direction. Any ideas what this thing is?
Justin
Old Feb 18, 2014 | 08:24 PM
Justinh's Avatar
Default found the noise
I found the noise. I looked in the engine compartment for anything that could rattle near the firewall and found the brake fluid tube and a controller above the ECM. After stabilizing both the noise stopped. But I can't tell which was the culprit because I undid my work and the noise has not returned.
Any idea what the controller/computer above the ECM is?
Old Feb 18, 2014 | 09:47 PM
skeeter's Avatar
some of the later years had a TCM, but not sure where it is located
Old Feb 19, 2014 | 07:52 AM
2008+ have a TCM and a PCM.
Year and model with every question.
Old Feb 20, 2014 | 07:23 PM
Justinh's Avatar
Sorry - 2010 base 3.7L.
bimbimmer4125
Jan 17, 2011 11:47 AM
jdrew
Apr 13, 2007 02:15 PM
importkiller
24
Sep 10, 2006 01:30 PM
dilo2001gt
Aug 18, 2006 11:06 PM
