what shroud h2 duramax
Old Apr 7, 2013 | 08:30 PM
rocky ward's Avatar
Default what shroud h2 duramax
Im finishing up my 2005 H2 SUT with a 2005 Durumax. I purchase a complete roll over truck so I had everything. I did the modification to the core support. If anyone can help what fan shroud are they using? Im trying not to use electric fans. Ive tryed the H2 shroud but the fan is to large and the silverado I will need to hack it
Old Mar 12, 2014 | 07:41 AM
beemc's Avatar
did you find a shroud ? aim doing a conversion and need a shroud but don't know what shroud to buy
Old Mar 13, 2014 | 11:54 AM
rocky ward's Avatar
I didn't find one so I went with a set of electric dual fans from Jegs are for a diesel come with a bracket that holds the computer also.
Old Mar 14, 2014 | 07:05 AM
beemc's Avatar
what did you do with the fuel tank and fuel lines
Old Mar 15, 2014 | 11:28 AM
rocky ward's Avatar
I used the hummer tank but used the fuel sending unit out of the diesel truck. Have you already started the swap? Motor bolted to the stock frame mount I used the stock trans cross member but cut the mount of the diesel cross member and welded it to the hummer cross member. you will need space out the core support also. I can get picks if anyone needs any.
Old Mar 16, 2014 | 11:05 AM
beemc's Avatar
yes i have the motor mounted to the frame i am almost ready to put the body on can you post pics of your radiator support
Old Mar 26, 2014 | 06:56 AM
beemc's Avatar
what did you do for the shifter cable ?
Old Mar 27, 2014 | 10:38 AM
rocky ward's Avatar
I used the hummer shifter cable its real close to the front drive shaft i modified the shifter bracket i think i added about a inch to it. you will need to lower the bottom of the core support radiator will set to high.
Old Mar 27, 2014 | 10:56 AM
rocky ward's Avatar
not a good fab guy lol
rocky ward
Jan 25, 2020 12:22 PM
GorillaH2
Mar 23, 2008 09:19 AM
slowpoke
Mar 3, 2008 10:00 AM
magnumoffroad
Feb 11, 2008 08:16 PM
bionichicken
Dec 24, 2007 04:00 AM
