What to look for? Problems?
Old Jan 23, 2012 | 08:54 PM
jsbihn's Avatar
Default What to look for? Problems?
Hey all,
I am new and I did a little search to find out what problems I need to look for when buying a H2.
The one I am looking at is white with a tan leather interior and a sunroof. I know that the door handles inside tend to chip on the early additions, and that the air bag suspension can get holes in it and the compressor could could go out, but is there anythng else I need to look out for?
I havent bought it yet, so now is the time to tell me about the issues to look for
I havent seen it yet except on the internet, so I want to make sure I go over the truck with a fine tooth comb.
Much gratitude to all those who share
Old Jan 23, 2012 | 09:37 PM
Caraddict's Avatar
I suggest paying for a mechanic inspection from a mechanic you trust before you buy it! $ well spent if they find something you overlook!
Old Jan 23, 2012 | 09:41 PM
jsbihn's Avatar
Well since it is in another state and I dont have a mechanic..... I was just wondering what else I might be able to do
Old Jan 24, 2012 | 09:38 AM
Cashville's Avatar
broken bolts on the manifolds, and also water infiltration from the front roof center lights
Old Jan 24, 2012 | 01:43 PM
olfart's Avatar
you don't sasy what year it is and if it has been offroaded alot. I bought a 2004 H2 in 2006 and here ai what I have done to it so far. Thank God most of it was covered under the extended warranty I got from the Stealership.
36,821 miles
12/15/06 – 37,600 - Battery
3/12/07 - 38,256 – Castrol GTX 5W30 oil – filter – wiper blades
3/18/07 - Replace Wiper Motor – Warranty
5/17/07 - 39,555 - Rotate tires
10/17/07 – 40,690 – Oil, Filter, Lube
10/23/07 – 40,861 – Air Filter Element – Update OnStar
5/1/08 – 42,660 – Oil, Filter, Lube
11/20/08 – 45,382 – Oil, Filter, Lube
2/3/09 – 45,777 – Warranty – Repair Shifter Wire – Replace Water Pump and Belt
5/19/09- 47,048 – Oil,filter,lube. Water leak from marker lights
7/21/09 – 48,120 – Warranty – Steering Pump and Pressure Valve, Front End align, Ex Manifold broken bolts, Remove Head, Pitman and Idler arms worn.
New Tires and front end alignment.
12/10/09 – 49,846 - Oil, filter, lube. Hood support cables rusted.
12/14/09 – 49,857 – Eng temp inst. stepping motor bad. Inst Cluster sent to be rebuilt
6/18/10 - 51,999 - Oil, Filter, Lube – 50,000 mi service
Replace leaking front axle seals
11/19/10 - 54,250 Oil, Filter, Lube
5/25/11 - 56,850 - Oil. filter, lube, rotate tires, replace rf running lamp
11/17/11 - 59,000 - Oil. filter, lube
BTW my 5 yr old battery just went dead this morning.
Still LOve the truck
I run on a few dirt roads where I live, but have never seriously offroaded it
Old Jan 24, 2012 | 03:01 PM
Mark R's Avatar
Originally Posted by Notsurewhatusernameyet
Hey all,
My Suggestion to you would be to contact a GM HUMMER Dealer (One who use to sell the brand) in that state and have them inspect the HUMMMER. After the inspection have them email you the report. You could pay them via CC over the phone. I figure the Dealer time at $90.00 to $120.00 per Hour. Wouldn't need more then 1 hourto inspect it.
Ask your seller if he is willing to drive it over and pay him for gas. If you blow $100 To $150 bucks to save thousands it's worth it ...JUst My $.02 Worth
Old Jan 24, 2012 | 09:49 PM
Caraddict's Avatar
I agree 100 percent!
samijane
Apr 18, 2014 07:58 AM
rtwash
Dec 13, 2013 10:45 PM
Andreas_Sweden
Jul 6, 2011 03:07 PM
Dennis
May 26, 2006 01:24 AM
ShopSAR
Mar 31, 2006 07:28 PM
