What did you do to your H3 Today
Flushed Brake Fluid, changed transfer case fluid.
tell us how u flushed the brake juice?
I drove it Lol
(Post 335661)
yeah, ive bled a few brakes, broken a lot of bleed valves,replaced a lot of wheel cylinders. i wonder if these valves stick like the old ones.
so im just curious just how someone did it. i think its a good thing to do and would like to do mine. |
I used a Motive Power Bleeder, simple, pump it up and go to each bleeder until it comes out clean. I use it on our Vette too.
https://www.motiveproducts.com/colle...er-bleeder-kit |
I took it for an off road ride!!
4 Attachment(s)
Some work i have done for my mom's '08 Alpha.
Installed Tru-Cool Max Transmission Oil Cooler OC-4739 and bypass radiator cooler. Replaced transmission filter and flushed transmission fluids. Changed transfer case, front and rear differential fluids. Changed engine oil and filter. Completely flushed cooling system and installed Evans Waterless coolant. Cleaned throttle body and MAF sensor. Installed 3 PIAA 520 SMR lights converted to 100W HID 5000K on the brush guard. Installed billet aluminum chrome hood handles. Cranked the torsion bar and leveled front suspension. Wheel alignment. Attachment 11150 Attachment 11151 Attachment 11152 Attachment 11153 |
Originally Posted by citiboy
(Post 335781)
Installed Tru-Cool Max Transmission Oil Cooler OC-4739 and bypass radiator cooler. Replaced transmission filter and flushed transmission fluids. Changed transfer case, front and rear differential fluids. Changed engine oil and filter. Completely flushed cooling system and installed Evans Waterless coolant. Cleaned throttle body and MAF sensor. Installed 3 PIAA 520 SMR lights converted to 100W HID 5000K on the brush guard. Cranked the torsion bar and leveled front suspension. Wheel alignment. http://i450.photobucket.com/albums/q...a/IMG_8296.jpg http://i450.photobucket.com/albums/q...a/IMG_8294.jpg http://i450.photobucket.com/albums/q...a/IMG_8300.jpg http://i450.photobucket.com/albums/q...a/IMG_8298.jpg btw, my T case is running low on oil, where's the refill plug? or I need to bring it down? |
Originally Posted by Mkawas
(Post 335783)
Looking good!
