What companies, 3 inch lift kit
Old Aug 10, 2007 | 06:32 PM
whododat's Avatar
Default What companies, 3 inch lift kit
Exactly what company makes the 3 inch lift kit? Yes I did a search.
My mistake I meant 3 inch lift
Old Aug 10, 2007 | 06:37 PM
671H3's Avatar
Default RE: What companies, 2 inch lift kit
I've never heard or seen a 2" lift kit for the H3.
Old Aug 10, 2007 | 07:03 PM
Gunner_45's Avatar
I've seen a 3, a 4 and a 10 inch kit...But no 2's.
The only thing I know of that would net you that type of increase is a front end leveling kit From Truxxx or Ready lift.
You can accomplish the same thing by cranking your T-Bars and going with some new shocks or extensions.
Old Aug 10, 2007 | 09:49 PM
Gunner_45's Avatar
Here is some Rancho propaganda: (from the G-Style web site)
Be sure to check out the part I hi-lited in red.
ProductName:
RANCHO H3 LIFT KIT / 06-07 HUMMER H3
OurPrice:
$2994.99
Availability:
In Stock
ProductNumber:
3KSRS655BB
Product Weight:
150 lb.
The off-road suspension experts at Rancho® are proud to introduce the industry's first suspension system for the Hummer H3. This world-class technology allows H3 owners to rival the off-road prowess of Rancho-equipped H2 models. This evolutionary new package allows customers to upgrade to 37-inch tires *. Among the many exclusive features is a state-of-the-art Rancho/Realift™ torsion bar relocation technology, which eliminates the need to relocate the factory torsion bar cross member - doing away with the need to cut and weld. Rancho® engineers also developed an ingenious two-piece cross member design that allows the installer to precisely relocate the differential - ensuring optimum suspension geometry and zero bump steer - without removing it from the vehicle. Our ultra-precise packaging of the cross member maintains maximum ground clearance; when combined with Rancho/Realift™ technology, this design substantially improves approach and departure angles. As with every Rancho® suspension, there are absolutely no compromises. In fact, our engineers maintained OE steering integrity - and eliminated time-consuming installation steps -- by preserving factory rack-and-pinion location. The system levels the rear to the new front height with premium Rancho® low-friction competition leaf spring packs. The result is a true upgrade in handling, ride comfort and performance. NOTE! * This kit was developed using a 325/60/R20 on 20x9" wheel with 5.0" of back-spacing. Use of the maximum tire size 37 x 12.50 will require some trimming of the front air dam/fascia & inner fender well for clearance. Rancho recommends using 4.5" of backspacing on 16", 17", and 18" wheels, 20" and above we recommend using 5.0" backspacing. Before installing any other wheel/tire combinations, consult your local tire & wheel specialist. NOTE! The dealer installed "Under Body Protection Package" will not reinstall on vehicles equipped with a Rancho Susp System. NOTE! The net raised height achieved with this system is dependent upon the adjustment of the torsion bars prior to installation. Example: If the Rancho System is listed as 3", but the torsion bars on a vehicle are adjusted to 1" over stock, the net raised height will be 2". Shocks not included. Custom order item. 06-07 Hummer H3.
Old Aug 11, 2007 | 07:20 AM
whododat's Avatar
$2994.99
What should I sell first, my maserati or lamborghini[8D]
Old Aug 11, 2007 | 07:47 AM
D VADER's Avatar
I'd like a 3" DROP KIT
jsbihn
Jan 6, 2015 10:48 PM
Kellonjford
Sep 17, 2013 11:35 AM
azz7772
Mar 6, 2011 11:41 AM
h2_32137
Mar 24, 2010 01:38 AM
littlehummerboy
May 16, 2007 09:36 AM
