Weak Batteries??
Old Feb 26, 2007 | 03:55 PM
jobenshain's Avatar
Default Weak Batteries??
Anyone else have trouble with your battery holding a charge??
I have been working on my stereo lately...and if I leave the ignition on
(without starting it) for more than 5-6 minutes - it drains the battery and
wont even turn over.
I wonder if I have a crappy battery or if the charging system is that weak??
Thanks.
Old Feb 26, 2007 | 04:01 PM
littlehummerboy's Avatar
Default RE: Weak Batteries??
Could be a bad battery, but...
Was the truck doing this BEFORE you started work on the stereo? Even if you goofed something on the stereo work (not sure what you were doing) it should either blow a fuse if incorrectly wired, melt some wires (you'd notice), or certainly last longer than a few minutes! Probably should have you dealer test it!
Old Feb 26, 2007 | 05:08 PM
Sugardaddy's Avatar
Mine has done this twice. I got a new battery and so far it seems ok.
Old Feb 26, 2007 | 05:14 PM
I've had my battery replaced TWICE under WARRANTY. Went and bought an Optima Yellow Top. No probs since!
Old Feb 26, 2007 | 05:21 PM
Sugardaddy's Avatar
I've heard that those Optima Yellow are excellent! If I have the problem again that's what I'm going to od too.
Old Feb 26, 2007 | 06:59 PM
jobenshain's Avatar
The only work I did to the stereo was to unplug the stock one and plug in a new 6-disc OEM deck.
So...I dont think I could have damaged anything.
But I have had this problem prior to installing the new deck.
I think its a weak battery...I guesss I should make an appointment at the dealer.
Thanks for the responses.
Old Feb 26, 2007 | 08:15 PM
ORIGINAL: jobenshain
Don't worry.....Definately POS Battery!![:@]
Old Feb 26, 2007 | 09:12 PM
blackstangs281's Avatar
AC Delco batteries are junk when they are new. Worse after you start the vehicle a few times with it.[:'(]
Old Feb 26, 2007 | 11:50 PM
CrazyGreek's Avatar
Ya, i have heard nothing but praise about the Optima Yellow Top!!
Old Mar 14, 2007 | 03:19 PM
jobenshain's Avatar
Went into the dealer...the battery tested bad...so they replaced. Seems better - so far...
We will see..
