Okay I have sealed both of my front marker lights and grommet with no luck. Still dripping one drop on driver dash and several on pass side dash and around grab bar. Only happens after severe down pours. NOT water hose. How hard is it to drop head liner?
Originally Posted by No more Jeeps
(Post 229653)
water leak
if you sealed both lights , and water is leaking in on both sides i bet that your leak is in the front winshield at the top , mike
Hello,
My 2007 h2 sut is now having that same problem! the corner light has been leaking for awhile now and now i just noticed that i have a lot of water coming in right at the center around the creases of the overhead lamps(interior)..like right in front of the rear view! wat the f...any ideas before i rip this thing apart? thanks |
I took off the the roof rack. The screws that hold it on have no RTV. You could see where water was leaking in. I would also check the three marker lights and rtv them and the corner lights. My sunroof drains were clean. Sad part it still leaks a little bit with heavy down pours. Oh well.
the most common water leaks on the h2 is fron the plug under the outside marker lights,all 4..also remember that there is also a star screws inside the roof rack,make sure you put silcone on the screws before you put them back in and also there is a small o-ring that also goes on the star screws,all h2 hummers have these..as far as the gasket goes on the outside markers,it is just there to keep them from rattling..has nothing to do with the gasket..the center light gaskets will go out from time to time and it is best that you replace with the much thicker ones,a set of 6 will cost you 45.00 on ebay..BOBCAT
Originally Posted by dphumv
(Post 235883)
hello,
my 2007 h2 sut is now having that same problem! The corner light has been leaking for awhile now and now i just noticed that i have a lot of water coming in right at the center around the creases of the overhead lamps(interior)..like right in front of the rear view! Wat the f...any ideas before i rip this thing apart? Thanks |
This was my fix! I wish I had found this one first in my quest. I was convinced it was the Sun Roof and nope this was it. Thanks for the great post
I'm having the same issue I check the roof lights added silicone n I still get it but I get the warter coming tru the floor is not so much the sunroof
I pulled that grommet up cleaned it and the metal there then put a beed of rtv around hole before ushing grommet back in, sealed mine up great, did both side and stopped all water leaking on mine, also a bit of rtv where wires come through the center of the rubber grmmet
