vin # check results... is this bad?
Old Sep 17, 2008 | 12:52 PM
Manofsteel's Avatar
Default vin # check results... is this bad?
This is whatwasretreived for my 97 Wagon, seems like a lot of work to me, but what do you guys make of it all:
2.20.97 259 MILES
REPLACE GLOW PLUG
REAR CHASSIS HARNESS
FUEL GAUGE
RIGHT SUNVISOR
3.24.97 2897 MILES
L/F HUB SEAL
FRONT TOE SET
GLOW PLUG
REAR OUTPUT SHAFT SEALS
REAR BRAKS AND A ROTOR
4.15.97 5987 MILES
O RINGS FOR MAIN A/C UNIT
SUCTION, A/C HOSE
10.27.97 12008 MILES
ALIGHN EXHAUST, HOOD
12.5.97 13582 MILES
REPLACE HYDRAULIC BRAKE BOOSTER
2.20.98 16124 MILES
TRANS CASE RECON, COOLER LOOP
LH ROCKER COVER GASKET
3.26.98 17379 MILES
FUEL PUMP
5.5.98 18150 MILES
VACUUM PUMP
10.15.98 20000 MILES
T-CASE PLUG
AMBIENT TEMP SWITCH
TRANS DIPSTICK TUBE SEAL
PITTMAN AND IDLER ARMS
LEFT OUTPUT SHAFT SEAL
FRONT ROTORS
10.12.01 29956 MILES
FUEL DRIVER SOLENOID
Old Sep 17, 2008 | 01:09 PM
hmcoleap's Avatar
Default RE: vin # check results... is this bad?
Nothing major there - seems like a lot of replaced seals early on, and more failures than usual (fuel, hydroboost, vacuum pump) but nothing to panic about. The t-case cooler loop is a routine/upgrade, same with the t-case plug. Idler and Pitman wear is common.
Old Sep 17, 2008 | 01:42 PM
Manofsteel's Avatar
Is this what I have to look forward to in the next couple years, lol? Or hopefully most of the kinks were worked out?
Old Sep 17, 2008 | 03:02 PM
phazer42's Avatar
you will notice that most of the folks on the H1 portion of this board also populate the humvee.net board.... which has all of the H1 info on it.....
Old Sep 17, 2008 | 05:53 PM
H1s required regualr service and maintenance. That is part of the deal when you buy one. Nothing on that list scares me at all. No service records beyond the ones you posted? Engine swap, HVAC replacement, etc?
Old Sep 18, 2008 | 08:30 AM
Manofsteel's Avatar
ORIGINAL: 3hummers
Sure I understand they require maint... I spent 6 years in the Army, actually worked in the motorpool too with all the HUMMVS. Unfortunately for me it was in the supply field ordering all the replacement parts for them and not actually working on them. As a driver was required to do a weekly and monthly PMCS (Preventative Maint and I can remember the "C"Schedule). I plan on buying the maint CD to help me.
Nothing past what I put up above, how could I get further records? I askedthe dealer (not a hummer, just a used car place) to talk to previous owner and see about service records on it. No updated HVAC though cuz I have the old style control panel with the 2 buttons on it (a/c and retriculation).
Not sure on the engine... I did get a 4 yr 100,000 mile additional warranty on the engine (including turbo) transmission, and all gaskets and seals (not sure if its for the whole truck or just the engine though) for $1000 well worth it I am sure.
Old Sep 18, 2008 | 08:32 AM
Manofsteel's Avatar
BTW 3 HUMMERS, how do you like your 97 wagon? Thats what I am picking up tomorrow. Gonna use mine as a daily driver... for the most part.
Old Sep 20, 2008 | 12:58 AM
I love my 97 wagon. It was my DD for awhile. Now it is my trail truck. I have the original HVAC and block and have had no real issues. Normal stuff, a few T case rebuilds, ***** joints, etc. It has been a real good truck. I think you will really like yours.
Old Sep 28, 2008 | 05:10 PM
White Out's Avatar
If I were to put my truck's history on here.... well I would need a few pages worth of space.
I have to say that yours isn't bad at all.
Nick
Old Jun 20, 2012 | 11:11 AM
djadds's Avatar
OK.
Speaking of Maintenance, could anyone direct me to a source for a 2002 H1 Schedule of Maintenance? Could I get it on CD/DVD? Hard Copy?
smpfalzer
Oct 4, 2013 03:56 PM
Bo
Mar 31, 2009 12:42 AM
HumminNBoatin
Apr 24, 2008 03:10 PM
MULEBRAIN
Feb 19, 2007 09:41 AM
HummerGuy
30
Sep 1, 2006 12:17 PM
