UK Towing
Old Jun 14, 2010 | 02:50 AM
Muzzer's Avatar
Default UK Towing
Hi, I need advice on the tow bar for the H3. Does the tow ball size differ from the English version. Is there any other problems that I need to know. The towing electric plug looks different to the UK ones, but I can easily change this. I will be getting the car in a couple of weeks and need to get it ready for towing. All it needs is the "slide in" part of the tow bar with the ball, that locks with a pin. Any suggestions on where to source this part in the UK would help.
Old Jun 14, 2010 | 05:35 PM
2wheelmonster's Avatar
what is the standard size of towing hitches where you live? then use an online metric to standard conversion calculator to figure it out, then i'm sure online there is a place you can get one.
Old Jun 15, 2010 | 02:10 AM
Bob Wolmer's Avatar
The real issue is what you're planning on towing it with. If you are planning on dragging it behind a vehicle under 3,500kg GVW, then you will be breaking the law as the maximum width to tow behind a vehicle less than 3,500kg is 2.3 metres so you can, and should, be stopped by the police every time you go out. If you use a vehicle over 3,500 kg then you are fine - the maximum width then is 2.55m.
Old Jun 15, 2010 | 11:17 AM
Muzzer's Avatar
Hi again, here in the UK, the standard size of tow ball in 1.96 inches, just wondering what the US standard size is. I plan on using the H3 to tow a twin axle caravan of just over 4000lbs. After an quick search on the net, I am unable to find any for the H3.
scubagirl
Jan 4, 2021 11:10 AM
dave85c4
Mar 15, 2006 05:24 PM
usmcman001
Jan 26, 2006 05:38 PM
ty_r1
Oct 25, 2005 03:47 PM
Syd R
Oct 5, 2005 06:04 PM
