Truck shut down on the parkway
Old Sep 18, 2008 | 04:41 PM
Herm's Avatar
Default Truck shut down on the parkway
Hi all!, was crusin on the parkway yesterday, doing bout 65mph...then it just shut off...I was able to pull off the road, waited a few minutes and it restarted no problem..I then called Kascar...they are pretty knowledgeable over there(nice guys) they said it could be a PMD issue...Ive read about this but just want to make sure these are PMD syptoms...
Old Sep 18, 2008 | 04:58 PM
Herm's Avatar
Default RE: Truck shut down on the parkway
PS 97 TD
Old Sep 18, 2008 | 05:11 PM
hmcoleap's Avatar
Yep - sounds like the classic FSD/PMD issue... try pouring some lukewarm water over the area of the PMD (to cool it) next time it stalls, and if it starts right up you will know you are on the right track.
Old Sep 18, 2008 | 06:33 PM
Herm's Avatar
Thats what I thought...It only did it when I was heavy on the pedal...it almost felt like a bucking and or a fuel issue...but as it cooled down it started back up I guess...and there not cheap those PMDs huh?
Old Sep 28, 2008 | 08:32 PM
mamedst's Avatar
i just replaced my pmd i paid 240.00 for the unit it self took 20 min to put in and now runs perfect i had the same prob as you did
Old Sep 28, 2008 | 09:40 PM
If it is the pmd it will start to happen more often also
Old Oct 1, 2008 | 01:57 AM
Hummer955's Avatar
Vibration & heat is what kills the PMD. The PMD isolators are more money but u will never get a repet problem. Bought mine from Heath Diesel in Washington. Good luck! (Had the same prob)
Old Oct 2, 2008 | 06:44 AM
Herm's Avatar
I just got the part, its from rubber duck I think??or duck something..got to look at the box again...will post the results when I install it..makes me feel better knowing that this a common problem and is repairable..
Old Oct 4, 2008 | 12:03 AM
Did you get the remote mounting harness also?
Old Oct 4, 2008 | 06:15 AM
Herm's Avatar
yep, the harness provided is like 3' long...
