Transfer Case
Old Jul 8, 2019 | 12:10 PM
h2finallyh2's Avatar
Default Transfer Case
Hi, I have an 2005 h2 and I haven't been able to switch into 4 low or 4 high. Every time I try to switch I get the service 4wd. Everything seems to work I hear the actuator click but it does not switch. I took it to a place and they said the transfer case is bad. Has anyone replaced or rebuilt a transfer case. If so what did you pay for it to get done.
Old Jul 8, 2019 | 10:19 PM
clsimmon's Avatar
I would be skeptical if is the transfer case until the encoder motor or transfer case shift control module has been completely ruled out. It is more times the encoder motor, than it is anything else. Even thought it "clicks" it still might not be rotating the gear selector completely within the transfer case and hence sending the failure code to the PCM/BCM.
Old Jul 9, 2019 | 01:47 PM
thank you so much for your help. Maybe I will try and replace that first and see what happens.
bigstick0000
Sep 17, 2020 09:29 PM
JamieNavaro
Dec 29, 2019 03:59 AM
charlie6017
Jun 11, 2019 12:22 PM
Donnie6983
Nov 19, 2017 12:11 AM
FatJay
Apr 20, 2017 06:36 AM
