Transfer case
Old Mar 12, 2018 | 08:51 AM
thorg113's Avatar
Default Transfer case
has anyone swapped the transfer case for a trailblazer ss transfer case?
Old Mar 12, 2018 | 09:10 AM
1st question, why? What do you think you may gain by doing that swap?
I believe there are many differences between the two cases. input shaft spine count and a few others.
Old Mar 12, 2018 | 09:12 AM
thorg113's Avatar
i have a 550 hp LS2 in it and don’t think the transfer case would hold up to the power. I know it will bolt to my transmission I got the 4l70e in it now which is set up for the stock transfer case at the moment. I was more less curious on how different the wiring would be
Old Mar 13, 2018 | 10:11 AM
Not sure if the t case control wiring will mate or if the case may need to be clocked to fit.
Good luck.
Why not delete the t case all together? The front diff will never handle that much power either.
Old Mar 13, 2018 | 10:17 AM
thorg113's Avatar
wouldn’t it be to late to delete it since I already have a 4 wheel drive Transmission
Old Mar 19, 2018 | 04:22 PM
atvspeed4's Avatar
H3 transfercase is passenger side drop, trailblazer is driverside drop.
The H3 case has a 1.5" wide chain and is a very stout case. The trailblazer SS case is nothing impressive.
Old Mar 19, 2018 | 04:23 PM
thorg113's Avatar
I just figured it would handle the horse power more than the stock h3 one
Old Mar 20, 2018 | 04:38 PM
650Hawk's Avatar
What's a "4 wheel drive transmission"?
Old Mar 20, 2018 | 04:41 PM
thorg113's Avatar
uh maybe the tail shaft being different?????????
Old Mar 21, 2018 | 10:32 AM
atvspeed4's Avatar
You'll be fine with the stock transfercase. There are several guys I know making more power than you and have not come close to damaging the stock transfercase. In my v8 alpha I have exploded a rear axle shaft, front 35 spline stub and fullsize cvs but transfercase is still fine.
