Train Horn Mounting in SUT
Old Feb 27, 2007 | 03:26 AM
H8MYX's Avatar
Default Train Horn Mounting in SUT
I have seen how other people have posted their horns before but I am looking for suggestions on a possible bracket design that will hold the compressor and tank so they don't have to be mounted directly to the wheel well.... below are pictures of the items I plan on using as well as some previous pictures from other installs.
any info or suggestions would be appreciated.
These are the horns I am going with
I am adding triple solenoids and will be running 2 3/8" Braided Lines from the tank thru the Drain hole... one will power the horns and the other is planned for running a second line with a quick connect for airing up and using a ratchet if works
I am going with a 3 gallon tank
and a Air Zenith Compressor with a 175 psi pressure valve on the tank
Old May 5, 2007 | 02:43 AM
MRDM1's Avatar
Default RE: Train Horn Mounting in SUT
any clip of the sound
Alex2012
Jul 11, 2012 12:57 PM
SafariHummerH2
May 27, 2010 11:47 AM
SafariHummerH2
Aug 15, 2009 06:48 AM
MRDM1
May 6, 2007 02:07 PM
MRDM1
Apr 26, 2007 12:31 AM
