TPMS..(tire pressure)..HELP....Throwing engine light on
Old Oct 4, 2009 | 08:33 PM
Mike_h306's Avatar
Default TPMS..(tire pressure)..HELP....Throwing engine light on
My H3 has brand new tires on it, which are the origanal tires...all the air pressure in the tires are the same....but it has a spare on the back that is flat.....
So its sending it in saying i have a low tire and Service the TPMS ....
But then yesterday the engine light came on.....Advance said it was saying check the TPMS system...
WILL THE TPMS CAUSE THE CHECK ENGINE LIGHT TO COME ON IF THE TIRE PRESSURE SENSOR LIGHT HAS BEEN ON FOR AWHILE ????
Old Oct 5, 2009 | 08:39 AM
RKSmith163's Avatar
TPMS system does not read the spare. There is a procedure in your manual to reset the TPMS. I would try that first. I do not think any of that would cause your CEL light to come on
Old Oct 5, 2009 | 10:13 AM
08H3's Avatar
'06's and early '07's did have a sensor in the spare, however the TPMS system only reads 4 tires at a time.
Old Oct 5, 2009 | 05:40 PM
Chrome Dome's Avatar
Yea he's right, my H3 tire pressure sensors can read the spare tire. It even says it in my manual.
Old Oct 5, 2009 | 09:21 PM
Spare tire TPMS school. Nope, the spare is NOT monitored. The TPMS in the 3s monitor only 4 tires at a time max, and are Not positional. The spare has a sensor, but the truck system can only monitor 4, not 5.
The only way the spare gets in the loop is if you rotate it in and reset all the tire sensors on the ground, that way the new spare that was on the ground before the rotation is then out of the loop. If you bought your 3 used, somebody before you may have programmed the spare in and never reset the tires on the ground.
This has been covered many times. Don't believe me, go out and let 20psi out of your spare to see what happens.... nothin.
Old Oct 5, 2009 | 09:24 PM
If you want your TPMS warning to go away, put exactly 38psi (up to 40) cold, in all four tires on the ground.
Old Oct 5, 2009 | 10:20 PM
08H3's Avatar
That's actually NOT what I was saying. What I was trying to point out is that even if your spare has a sensor installed, it does not mean it's monitored. The system monitors 4 tires exactly. No more, no less.
Old Oct 6, 2009 | 07:26 AM
Yeah.... that.
Old Oct 6, 2009 | 09:27 AM
Mike_h306's Avatar
well i done the little trick in the book that it says to do, drove it down the road and the light on the dash went off.
Check engine light is giving me a TCC control modelue on my transmission valve body. thats why the light was on.
Harold
Jan 28, 2012 11:06 PM
luxh3
Mar 18, 2011 05:32 AM
psych0
Sep 16, 2010 05:35 AM
johnnie hummer
Aug 19, 2010 07:36 PM
myfirstH3
Oct 24, 2009 08:11 AM
