tonneau cover help
Old May 28, 2007 | 09:10 PM
ghoticov's Avatar
Default tonneau cover help
The 05 Black H2 SUT we bought came with a tonneau cover but it is not on. I was wondering how hard it is to put on, does anyone know? I have all the parts to do it, I am just not sure where to start or how to do it.
Thanks!
Marc
Old May 29, 2007 | 04:08 AM
blackstangs281's Avatar
Default RE: tonneau cover help
Is any part of it installed on the truck? The reason I ask is because, if the rails are installed, the lid is easy to put on. If the whole thing needs installed, you might want to get the dealer to do it. It even takes them 2 to 3 hours to install one.
Old May 29, 2007 | 07:46 AM
ghoticov's Avatar
ORIGINAL: blackstangs281
Yes, the rails are on but the part that connects to cover to the rails is not (the two "arms" that hold it up).
I can see the rails on each side but there is nothing in the rails. Is that what you mean?
Old May 29, 2007 | 01:59 PM
If the rails are on the truck, then all you need to do is put the top on. If they took it off the easy way, you should only have to mess with 6 bolts.
At the base of each shock there should be three holes on the brackets. If everything is on there right, they should line up with the rails near the back.
If you need pic's of mine installed, let me know.
Old May 29, 2007 | 06:04 PM
ghoticov's Avatar
I need pics!!!!!!!!!!!!!! LOL
The rails are installed but have quite a few parts (screws, bolts and brackets) that are just in a bag. I assume the brackets have to be installed also, I am not sure how it goes together though. I will go take some pics of how it looks and post them.
Old May 29, 2007 | 06:19 PM
ghoticov's Avatar
Old May 29, 2007 | 07:01 PM
You don't have the rails on there. Did he give you the side rails? I don't see them in the pic.
To install the whole thing, it can take hours. I would not want to do it[:@] Hummer had a crappy design with the cover. It is way to involved to take the whole thing off and on.
Here are some pic's of mine, and you can see the side rails. Once the cover is on, you can remove the 3 hex bolts at the bottom of the shock on each side. This will remove the cover and leave everything else there so you don't have to line it up again.
Pardon the dirt
Old May 29, 2007 | 08:02 PM
ghoticov's Avatar
Pardon the dirt
Ok, so now I am REALLY confused. LOL Is it just me or does your's look different? Your rail part doesn't look like my rails, does it? I can tell I am missing the two large parts and I think that is what is in my bag but it looks nearly impossible to figure out how they all go together.
I did read somewhere that putting them on can be a bitch because it has to be lined up right. And being that I have no idea what I am doing, I might just let someone that knows what they are doing do it. I found someone that will put it on for $50 so I think I may save the headache and have them do it.
Thanks for the pics!
Old May 29, 2007 | 08:07 PM
Your rails are the same. You take all that stuff off of mine and it looks just like yours. If it was me............I'd let someone else do it
Old May 29, 2007 | 08:24 PM
ghoticov's Avatar
Yea, that's what we are going to do. I would hate to screw something up.
TAINTER
Nov 10, 2013 12:50 PM
BigHop51
Jun 9, 2011 02:17 PM
finall
May 11, 2008 02:03 PM
jstdoitt21
Dec 18, 2007 04:46 PM
flamethrower
Mar 28, 2006 10:02 AM
