tire size question
Old Jan 17, 2009 | 03:09 PM
oyealiz's Avatar
Default tire size question
I've located an h3 that I really like, and it has 33" toyos. Is this likely to cause a rubbing issue?
Also, what has to be done to calibrate the speedo when tires like that are added? I'm just wondering if the owner corrected for the tire size change.
Old Jan 18, 2009 | 08:30 PM
BMJM100's Avatar
Default RE: tire size question
The H3 when ordered with the off-road suspension will come fitted with 33" Dunlops. Speedo is calibrated to correct it, but it has been talked about here that it was still off just slightly.
Old Jan 19, 2009 | 10:01 AM
33s will not rub. If it was a base or Lux with the 32s stock, your speedo will only be off a small amount, like 2mph at 55? You can calibrate the speedo through the PCM, so if you get a PCM tune you can have that done at the same time.
Andreas_Sweden
Mar 19, 2025 12:16 PM
Hummer79
Jan 7, 2013 11:28 PM
Biggun
Nov 21, 2011 11:57 PM
jemche
Nov 9, 2010 03:58 PM
IN2deep
Oct 15, 2007 09:23 PM
