Tire Pressure Sensor (TPS) monitor - What a PITA
Old Apr 13, 2008 | 08:55 AM
Default RE: Tire Pressure Sensor (TPS) monitor - What a PITA
From this old thread: RE: Mounting a wheel back on the H3?
I posted this, and it all applies to the 2007.
[align=left]"From the H3 06 Owners Manual: [/align][align=left][/align][align=left]TPMS Sensor Identification Codes[/align][font=arial][color=#231f20][size=1][align=left]Each TPMS sensor has a unique identification code. Any time you rotate your vehicle’s tires or replace one or[/align][align=left]more of the TPM sensors, the identification codes will need to be matched to the new tire/wheel position.[/align][align=left]The sensors are matched to the tire/wheel positions in the following order:[/align][align=left]left front (LF), right front (RF), right rear (RR) and left rear (LR).[/align][align=left]You will have one minute to match the first tire/wheel position, and five minutes overall to match all four[/align][align=left]tire/wheel positions. If it takes longer than one minute, to match the first tire and wheel, or more than [/align][align=left]five minutes to match all four tire and wheel positions the matching process stops and you will need to start over.[/align][align=left][/align][font=arial][color=#231f20][size=1][align=left]The TPM sensor matching procedure is outlined below:[/align][align=left]1. Set the parking brake.[/align][align=left]2. Turn the ignition switch to ON with the engine off.[/align][align=left]3. Turn the exterior lamp switch from AUTO to ON four times within three seconds. A double horn[/align][align=left]chirp will sound and the TPMS low tire warning light will begin to flash. The double horn chirp and[/align][align=left]flashing TPMS warning light indicates the TPM matching process has started. The TPMS warning[/align][align=left]light should continue flashing throughout the matching procedure. The SERV TPM message will[/align][align=left]be displayed on the Driver Information Center (DIC).[/align][align=left]4. Start with the left (driver’s side) front tire.[/align][align=left]5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or[/align][align=left]decreasing the tire’s air pressure for 10 seconds, then stop and listen for a single horn chirp.[/align][align=left]The single horn chirp should sound within 15 seconds, confirming that the sensor identification[/align][align=left]code has been matched to this tire and wheel position. If you do not hear the confirming single[/align][align=left]horn chirp, you will need to start over with step number one. To let air-pressure out of a tire you can[/align][align=left]use the pointy end of the valve cap, a pencil-style air pressure gage or a key.[/align][align=left]6. Proceed to the right (passenger’s side) front tire, and repeat the procedure in Step 5.[/align][align=left]7. Proceed to the right (passenger’s side) rear tire, and repeat the procedure in Step 5.[/align][align=left]8. Proceed to the left (driver’s side) rear tire, and repeat the procedure in Step 5.[/align][align=left][size=2]9. After hearing the confirming
Old Apr 13, 2008 | 09:39 AM
HummerGuy's Avatar
That's what I though, until the warning message didn't go away. I'm hoping once I drive it this morning it will.
Thanks again Doc. We'll see what happens [&:]
Old Apr 13, 2008 | 05:17 PM
HummerGuy's Avatar
Well, the error message went away after the truck started moving, so apparently doing it isn't enough. It has to actually move for it to go away. Very odd.
Bee Double-You
32
Jun 15, 2017 04:36 PM
theBroken
Feb 9, 2011 06:55 PM
katbear
Jun 2, 2009 10:40 AM
machines
Oct 17, 2007 03:24 PM
jpac4lyf
25
Jul 27, 2007 11:13 AM
