Timing chain and valves
Old Feb 28, 2008 | 04:03 AM
ALLROADSHOP's Avatar
Default Timing chain and valves
Hi all,
after some works on my H3 a also change cylinder head for the improved one, but I left same valve shaft. No I have a litle poblem with exact timing of the chain wheels and valve shaft. Do you anybody knows if there is necesity of some speciale tool to time it right way or some other special hint???
Or better way if you anybody have the complete service manual and if you will make a scan or copy of the right part?
Thank you very much
Petr
Old Feb 29, 2008 | 12:49 PM
RealJeep's Avatar
Default RE: Timing chain and valves
Petr,
If you can't get a good answer from the H3 groups then check the Chevy Colorado groups too...Same engine.
Petr, [/align]Wenn Sie nicht eine gute Antwort von den Gruppen H3 erhalten können dann, überprüfen Sie die Chevy Kolorado Gruppen auch... die gleiche Maschine.[/align]
Aaron Forjone
Dec 10, 2013 12:54 PM
tmleadr03
Jan 3, 2013 10:15 AM
hangout
Sep 15, 2012 08:15 PM
bigdog100
Feb 22, 2012 12:52 PM
bigdanes
Sep 26, 2007 09:56 AM
