Tie Rod and CV Part Numbers?
Old May 13, 2008 | 07:38 PM
GarrettMoore's Avatar
Default Tie Rod and CV Part Numbers?
Can anyone show me on GMPartsDirect.com exactly what needs to be ordered to fix the common breakages of tie-rods and CV's?
For example, I don't know if I need the inner, or outer tie rod, or both?
And I don't have a clue on the CV's...
Old May 13, 2008 | 08:10 PM
Sewie's Avatar
Default RE: Tie Rod and CV Part Numbers?
The outer TRE is usually what bends/breaks, but you should carry both inner/outer to be safe. And you want the larger 16mm ones so get ones for a 07-08 model. I don't have the p/n handy but can get it if you need.
The CV is listed in the catalog as an axle assembly, but gmpartsdirect doesn't show a price. Again, I should be able to get you a part number if needed. Just gotta go through my paperwork when I get home.
Old May 14, 2008 | 12:47 AM
Sewie's Avatar
Part numbers for 16mm tie-rod ends
Inner 15907712
Outer 25781473
Can't find the paperwork with the CV part numbers. You should be able to get it by calling the dealership.
Old May 14, 2008 | 10:17 AM
If I purchase the entire axle assembly I should just be able to remove the entire old unit and slip this one in while only removing the brake caliper and spindle nut, right?
Thanks Sewie.
Old May 17, 2008 | 02:10 AM
Sewie's Avatar
You will also need to remove the bolt for the upper A-arm. That should allow you to tilt the knuckle outward enough to get the half-shaft out.
Ridicrick
Aug 21, 2010 08:22 PM
TINKED
Jun 30, 2008 06:17 PM
bsmitty
Oct 4, 2007 01:15 PM
inked
17
Apr 26, 2007 05:02 PM
yodawagon
Jan 28, 2006 03:16 PM
