Ticking noise...
Old Dec 6, 2010 | 02:23 PM
H3DONIST's Avatar
Default Ticking noise...
I did a search, but couldn't really find a thread that has the same issue I'm experiencing.
My truck started to make a ticking noise coming from the front passenger tire area. It will increase/decrease depending on my speed. It usually only makes the noise when I'm not on the gas. At slow speeds (5-10mph) it seems to be worse and will occasionally "pop" instead of tick. It does it in forward, reverse and neutral. It does not happen when I'm not moving, so I don't think it's related to the engine or transmission.
I've looked underneath, but I don't see anything broken or dangling. I'm a PC tech and not a mechanic, so I haven't wiggled anything or taken anything off.
I don't know if this will help any of you mechanically inclined folks to throw out some suggestions of possible causes, but I figured I would ask anyway.
Old Dec 7, 2010 | 02:48 AM
Widespread Hummer's Avatar
IS the sound you're describing a much faster tick than you would hear from an exhaust manifold? I am assuming you have ruled out any problems wiht the exhaust manifold already, cracked manifold, broken bolt. You say at slow speeds, does the sound stay consistent as the vehicle goes through the gears?
Old Dec 7, 2010 | 07:49 AM
J.W.'s Avatar
If the noise is proportional to your speed but not how much gas you are giving it, my guess would be a wheel bearing.
Old Dec 7, 2010 | 11:29 AM
Yep, me too.
Roll down the window, get it up to speed, and coast out of the throttle, if it is still there, wheel bearing is a very good guess.
Old Dec 7, 2010 | 01:40 PM
H3DONIST's Avatar
Just got the truck back from the shop today and it ended up being the drive shaft on the passenger side.
nathanandthekid@hotmail.com
Jun 12, 2014 01:11 PM
ekeef
Dec 14, 2012 09:54 AM
mdavis
Jul 15, 2010 03:10 PM
THE BEAST
16
Oct 23, 2009 03:30 AM
HammerDown
Aug 30, 2007 04:54 PM
