Think I ruined truck, Help?
Old Jan 25, 2011 | 10:47 PM
SublimeHummer's Avatar
Default Think I ruined truck, Help?
Today I tried to be a cheap *** and save money and change transfer case fluid, now truck wont shift out of first gear. Got info from this site, http://www.gmhummer.com/forums/showt...?t=1628&page=3,
any help is much appreciated, one thing i know i could have done wrong is instead of draing plug mark in picture, i use plug right below it, taught that was the plug, I feel like crap right now, I should of just took it to a professional, I did recheck sensor and make sure it was on properly, please till me its an easy fix, thank you
Old Jan 25, 2011 | 10:58 PM
drtom's Avatar
Banned
Default t case? transmission?
1st gear is in the transmission.
has nothing to do with t case fluid,,,,so what did u do???
Old Jan 25, 2011 | 11:14 PM
thanks for the reply DrTom, truck work fine before i tried to drain and fill transfer case, filled from transfer case sensor like it said on site, have a 2006 h3 adventure, as you could till I have no clue what i did wrong, my friend use to be a mechanic said he'll stop by in morning, I hope whatever I did can be fixed and nothing major.
Old Jan 26, 2011 | 05:01 AM
drtom's Avatar
Banned
Default long range guess,,,
its prob stuk in lo lock.
u think its in first. sensor? wire??
Old Jan 26, 2011 | 09:32 AM
Changing TC fluid in and of itself won't do squat regarding shifting. You can drive with a shattered or dry T case until it toasts. So my guess is you should be checking that you correctly clipped the speed sensor connecter back on, if it is not getting the proper signal, the PCM will not read your "speed", hence no shift.
Good luck.
Old Jan 26, 2011 | 10:01 AM
Thanks doc, I'll check the sensor again, if the sensor was not installed right or is not working would i get a check engine light? Thanks for your help
Old Jan 26, 2011 | 10:21 AM
CEL from the T Case? You can put a code reader on it if you want.
Old Jan 26, 2011 | 02:20 PM
Well, taking a friends advice, I added another half a quart of oil, and everything works fine now. Was just about to call AAA to take to dealership. DrTom, and Doc thanks again for the advice.
Old Jan 26, 2011 | 02:25 PM
PNW-H3's Avatar
probably was that you had a bad connection on the speed sensor. It will not shift out of first if it is unhooked or malfunctioning.
Old Jan 26, 2011 | 02:41 PM
It could of been, but I took sensor out, connected it back about 6 times with no luck, added another half a qt of oil, and now it shifts fine, my service guy at dealer said same thing, not enough oil should have nothing to do with it not shifting in gear take it in 120 to look at it. Just glad everything worked out, now I can sleep better at night.
Mike Sandelier
Nov 21, 2012 10:38 PM
ar0521
May 2, 2011 06:41 PM
NewYorkLuxuryRides
Jan 20, 2011 10:54 AM
myrddin
Jan 10, 2011 01:35 PM
dilo2001gt
Aug 17, 2006 10:54 PM
