Thermostat Replacement
Old Nov 27, 2013 | 01:47 PM
happythree's Avatar
Default @ rsc
[QUOTE][ less fluctuation in use as the thermostat didnt cycle open/closed as often and better temp control /QUOTE]
I wonder why you get less fluctuation with less open/close cycles? one big gulp of cold water,close,heat it up to HOT then open and take in another gulp!
some t stats have small hole/bypass to trickle water thru so it soften the cold rush or cold shock they call it.
im also curious why you have such a high temp in an ambient of 100 when I have never been over 195 in ambient of 95.
and anytime I ever had a car over heat the quik fix was a fast run down the road. why would you run hotter going fast with 100 deg air to cool your 200 deg radiator?
if a car doesn't settle at the t stat temp in decent temps I think it has other trouble.
oh, the stat always is in engine hot water.
Old Nov 27, 2013 | 03:19 PM
Ground Pounder's Avatar
Originally Posted by khanson.82
Same location for 3.7.
I actually just found this done on the 3.7.
https://sites.google.com/site/happyh...ts-replacement
Thanks !
Old Nov 27, 2013 | 06:56 PM
rsc's Avatar
rsc
[QUOTE=happythree;304991]
The year I bought my H3 the temps from May to September was at least 100 every day. Luckily that year the temps stayed just about 105, usually they hit the teens for a couple of weeks at a time in south Texas. I think the temp climbs on the hwy because the engine is working so much harder to maintain the higher hwy speeds with our aerodynamics. Add big tires and a roof rack plus a couple people wanting a/c and you can see the added effect. It would be like towing a boat or driving up an incline the whole time so you are pouring a lot more heat into the engine.
Anyway, shock cooling is a concern but I think that since the thermostat is not an either all open or closed valve that the shock cooling probably would not be a factor. I think having the thermostat closer to the temp probe that this may have something to do with the more stable temperatures too.
Old Nov 27, 2013 | 09:56 PM
happythree's Avatar
when you say they had more stable temps,just how stable?. mine sits on 195 and never move 2 deg. how mucjh better do you want/need to be?
the stat looks like its more central in this block than any other I saw right up front or on one side of a v6/v8 and it is on the output of the engine feeding into the rad huh.
where does the new in line stat go?
Old Nov 28, 2013 | 01:27 AM
rsc's Avatar
rsc
Apologies in advance for cross-linking to a post on another site, but it is relevant to the discussion- How's this engine coolant temperature?
This should give you the backstory on this mod.
Old Nov 28, 2013 | 07:39 AM
happythree's Avatar
I could not find the link info.
I enjoy an ongoing discussion on a topic to bring out new information.
you will see that I read and comment/question most all comments made by others point by point.
when my points/questions are ignored I end my participation!
end
Old Nov 28, 2013 | 08:26 AM
rsc's Avatar
rsc
I dont know why, the link works for me. Google "h3 thermostat jegs 53260 housing".
Piranha
Jun 27, 2015 04:43 PM
parrip
Feb 19, 2014 09:13 AM
jandmtv
Jun 2, 2011 06:17 PM
c3 rolling
Jan 23, 2009 06:30 PM
veves
May 31, 2008 09:34 PM
