Aliexpress is the China ebay
Originally Posted by legerwn
(Post 349257)
For programing the next option is MDI with a pass to the GM site, usually around 55$ for 3 days.
this is probably my next purchase or maybe the AUTEL unit Neal |
Autel MaxiSYS MS906TS Diagnostic Tablet with TPMS, don't have a clue if it does programing yet, still checking but its been said its the best all around scanner out there today.
Neal |
(Post 349266)
Neal For 1800$, it should dance and not only reprogram hahahaha |
Originally Posted by faresmotors
(Post 349232)
wondering why HUMMER is not shown in the GM vehicle list...
(Post 349255)
Tech 2 doesn't program for H2 above 2007... what to do in that case?
https://www.acdelcotds.com/acdelco/action/subscribehome This is ONLY needed if you want to program or update the software in a module. ALL of the build in diagnostics and testing for vehicles up to 2013 works without the subscription or the older TIS2000 software. You only need those for doing actual programming. The older TIS2000 software - that is what has the programming was discontinued in 2007. TIS2000 does have the actual programming for all vehicles up to 2007. After 2007 GM went to the TDS system. You can also get a newer style MDI or MDI 2 for diagnostics and programming. The catch with those. They have NO screen or built in software and you must pay for a subscription from from ACDelco TDS to use an MDI. Other brand units, a very select few can do actual programming and use the pass-through method. NONE have the diagnostics that the actual Tech2 or MDI (with the subscription) will have. Check with Autel and see if they have the full diagnostics and re-calibration for the rear air suspension on a Hummer H2. Not going to happen, there is too little demand for them to hack and reverse engineer that particular bit of code in a Tech2 to figure out the diagnostics and then write programming for that for their tool. |
Originally Posted by MixManSC
(Post 349382)
You can also get a newer style MDI or MDI 2 for diagnostics and programming. The catch with those. They have NO screen or built in software and you must pay for a subscription from from ACDelco TDS to use an MDI. I have found: 1- Tech 2 2- VAUXHALL DEALER LEVEL LAPTOP GDS2 TECH 2 GLOBAL TIS TECHLINE TIS2000 Almost same price. Which option do you recommend me to go with? |
(Post 349255)
https://cimg2.ibsrv.net/gimg/www.hum...bdd5446094.jpg MY https://cimg3.ibsrv.net/gimg/www.hum...e866bfc17c.jpg |
I've used my Tech2 on my 08 many times for troubleshooting not programming
Neal |
I was bought gm tech2 scanner from http://www.obd2eshop.com,this site has good after-sales serive,I like it.theri said both Both the original and HQ clone can work for hummer cars
tech support:Can I have a cheap Tech 2 for Hummer? | OBD2eShop official blog |
Sorry - should have replied months ago but missed it for some reason. For programming you also need to have TIS2000 running on a computer or pay GM for a 24 month subscription for their TIS2WEB (Vehicle Programming) for $40 https://www.acdelcotds.com/acdelco/action/subscribehome
The computer will need a serial port for downloading the programming to the Tech2 for programming your vehicle. The way programming works is you connect the Tech2 to the vehicle and tell it you want to program a module. It interrogates all of the modules on the vehicle for the current versions and the VIN number. You then connect it to the computer running TIS2000, GlobalTIS, or TIS2WEB subscription and select programming in the computer. It reads the Tech2 for the vehicle info and then presents you with a list of software for all of the modules and shows you which have updated software. I recommend only doing one module at a time which is a good bit more back and forth but safer. The computer then loads the update to the Tech2. You take that back to the vehicle and connect it and it then programs the module. The best, most reliable and safest method is to use a long enough serial cable (its uses 9 pin serial adapters with an ethernet cable to make the cable longer - so you can just use a longer network cable) and do pass-through programming. In that method the process is the same but you leave the Tech2 connected to both the computer and the vehicle at the same time. Once you select programming on the Tech2 then go to the computer and you can immediately update each module right from the computer. There is a slightly more updated version of standalone TIS2000 floating around on the web which has additional updates that has software updates for vehicles through 2009 as well. I know just using that TIS2000 both my GMC truck and my 2003 H2 both had a bunch of software updates available to be programmed all of which fix small issues or improve certain aspects. One example in on the older single compressor air ride like my 2003. Those would run and make small adjustments a LOT more often than needed and the software update fixed that. On the H2 the rear air ride is also one to be very careful of for doing software updates though. For example, my 2003 came with the earlier style single compressor but if it were to fail a dealership would replace it with the newer style dual pump compressor. Programming would still think its the original style and would attempt to program it and that would actually cause it to fail. TIS2000, (Global, Web, etc) will warn you about this sort of thing though so just heed all warnings and follow instructions and its fine. The programming aspect is not needed or required to use the Tech2. The Tech2 still gives you a TON of diagnostics and tests that NO other OBD device has including things like the air ride module, detailed BCM functions, basically you can control and test every computer module in the vehicle. |
