TC & Differential Maintenance Questions
Old Aug 9, 2011 | 08:08 PM
  #21
drtom's Avatar
Banned
Old Aug 11, 2011 | 08:16 AM
  #22
Widespread Hummer's Avatar
Both Diffs have drain plugs, so the synthetic diff lube can easily be drained and then refilled.
First remove the drain plug using a 3/8" drive socket wrench w/ short extension. While that is draining into a pan, remover the fill plug. Let them drain a good long while, and wipe off the drain plug. I also like to squirt in some clean gear lube when drained to sort of wash out any last residue, then put the drain plug back in. You do not need to use lock tight or teflon tape, I have never had the drain plug leak after snugged in place.
Then fill with synthetic 75W-90 up to the level of the fill plug, put the fill plug back in and snug.
The front spec capacity is 1.5 Qts (1.45L), rear is 2.1 Qts (2.0L) so to do both you will need to buy 4 Qts, and have some left over even if you do squirt in a bit for the wash out like described above.
I used Mobil One synthetic as it was on sale cheaper than the other brands.
There is another thread on T Case procedure.
I missed that part the first time and got very nervous when I put 2 qts in and it wasn't to the hole. I was certain the ground must not have been level and almost did the whole thing over. I would have been terrified if I started in the front and could only get 1.5 qts in. I guess I assumed they were 2 and 2
samiparts
Aug 23, 2016 01:10 PM
andersh
Feb 5, 2012 09:50 AM
Dirtman2009
Jan 20, 2010 09:00 AM
Gunner_45
Feb 5, 2007 12:59 AM
CarlosC
Nov 1, 2006 12:58 PM
